Results 1 to 32 of 32
    Dec 2012
    231
    How much mayo is too much?
    Just checked under my oil cap an found this:
    Now to me that looks pretty bad. What should I do?
    2010 Condor Grey S3 Sportback S-Tronic. 353bhp 400ft/lb.
    Jan 2012
    SW London
    751
    Thats what she said...
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Jan 2012
    SW London
    751
    Lol sorry couldnt help it. That does look like quite a bit but then ive seen other cars with build up like that just not as much. Change ur oil and clean up the cap if ur worried and see how u get on. Is ur coolant still clean?
    VCDS User
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,159
    Try an oil change, or go on a few long runs.
    Dec 2012
    231
    Lol!
    Coolant is still clean.
    I'll clean it up an see how it goes, I'll do an oil change in a few months its only just had it done when I bought it in January
    Sportback owner
    Apr 2007
    France
    465
    If the oil was changed only two months ago, then that is indeed indicates a lot of moisture in the engine. I half suspect that the oil was not changed at all, but I could be wrong. Any sign of coolent loss? Could be the nasty cold weather, but I would think the best thing to do is to take the car on a good long run asap, and try to burn off that crankcase moisture. Otherwise, change the oil and then give it a spin.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Dec 2012
    231
    That could be true mate about the oil not being changed, so may well be due now.
    No sign of coolant loss. It had a good 200 mile run 2 weeks ago but since then it's just been round town, I've just been an cleaned it all out and will monitor it and get some oil ordered.
    Jun 2011
    125
    get a oil catch can, will trap all that stuff instead of burning in engine
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Dec 2012
    231
    I thought about a catch can but I thought they were to stop the oil getting back into the intake side
    monopole's Avatar
    Oct 2012
    240
    Quote Originally Posted by H17YD L View Post
    Mine has 4000m on the clock and has just as much around the oil filler cap, I looked last night when I had it in the hangar to check the tyres, had a TPMS light. I really cant see it being an issue if a 4000 mile engine and being 5 months old has it??????
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Phantom Black
    -outgoing (63) A5 2.0TDI (177) Black Edition S-Tronic Coupe Quattro
    Phantom Black
    VCDS Location: NI (East Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Dec 2012
    231
    That's reassuring to know! Thanks.
    I was looking at pcv deletes an catch cans.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Dip your chips in it.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Dec 2012
    231
    Tried an it must be light mayo as it tastes sh1t lol
    I thought I'd check the PCV for the same build up, here's the pics:
    ImageUploadedByTapatalk 21364230434.281527.jpgImageUploadedByTapatalk 21364230468.657918.jpgImageUploadedByTapatalk 21364230488.744600.jpgImageUploadedByTapatalk 21364230506.195094.jpg
    So is all that still acceptable? And there is another layer under the cap and in the spout, after wiping it all clean yesterday! Only drove to work an back, 3 miles each way which is probably part of the reason I'm getting this, but I'm sure it's no supposed to be this bad, ordering the oil tomorrow and filter, also going to get some engine flush.
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    122
    Personally i would not consider any mayo acceptable.
    If i was buying a car with even a hint of mayo anywhere in the oil system i'd walk away.
    If i noticed that on my car then i would change the oil straight away and monitor it after that.
    The mayo is water mixing with the oil, so you have water getting into the system somewhere where it shouldn't be.
    Even if it was a faulty PCV then the water is still coming from somewhere, as it certainly isn't coming from your intake system.
    Quick question.
    How do you use the car, is it used for lots of shorts runs or does it sit for long periods of time?
    First thing i'd do is check the dip stick, if the oil is coming out as mayo on the dipstick then i would strongly advise not using the car until you've both changed the oil and rectified the fault.
    How is the coolant level?
    Have you noticed the car is putting out more smoke (from the exhaust)?
    Dec 2012
    231
    Quote Originally Posted by gixerson View Post
    Quick question.
    I normally think like yourself and if I'd of noticed that when buying I would have been well put off! But a lot of people seem to think its nothing.
    Haven't a clue where the waters coming from and before when I checked the dipstick there was a tiny bit on the end of it, I wiped it and checked again but nothing the second time.
    Coolant level is spot on, and the regular pink colour, it's slightly above the max line when hot and settles just on it when cool.
    The car does a lot of short journeys but all my cars have done the same and none have had any thing like this.
    Not noticed any more smoke from the exhaust when I boot it either?
    I'm going to get the oil and filter ordered and avoid using it now till I've done the oil change.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,070
    It's the short runs take it for a good blast and I'm sure that will cure the mayo it's normal for these engines on short runs
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Your work commute is only 3 miles. That's the problem. The engine doesn't get up to temperature and it causes any condensation to form into water causing the mayo. A good old hot run will help things.
    monopole's Avatar
    Oct 2012
    240
    My work commute is 16miles each way, roughly 12 of those 16 on motorway, so surely the trip duration can be discounted as a factor.
    No mayo on my dipstick (just the filler cap)
    Phantom Black
    Dec 2012
    231
    Well, I've decided to leave it at home today an get the oil, filter an flush ordered, do all that an monitor. I read somewhere that the viscosity of the oil can make a difference, and seeing as the car place I bought it from didn't give a sh1t so it could have anything in! So going to get the proper 5w30 edge put in and give it all a good clean out at the weekend, I'll update with my findings, I'll also look into a catch can.
    jaydav2306's Avatar
    The solution to this if you are only doing 3 miles is simple. Wipe all the excess and clean, then drive the car for approx 30 miles on the back roads like you stole it. This should sort it
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    monopole's Avatar
    Oct 2012
    240
    you read the whole thread and came up with that?
    Phantom Black
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I have the same issue on the Ducati as most of the Duc owners have. Short rides in the cold makes the sight glass mist up . A good run getting the oil really hot & its gone
    PS you need a Milltek fitting, that will cure it
    Dec 2012
    231
    Cheers! It seems it will go away after a good run but I'm swapping the oil anyway so I know what's in it.
    If I could get a milltek cheap enough I'd have it straight on lol
    jaydav2306's Avatar
    Quote Originally Posted by monopole View Post
    Oil change every 5K too is what I do, I only do short runs also so it's my solution
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    A compression test, to set your mind at rest.
    Dec 2012
    231
    Quote Originally Posted by jaydav2306 View Post
    So you have this trouble also? As much as mine on the cap? I dont mind doing 5k changes that would be every 10-12 months anyway
    Quote Originally Posted by autolatry View Post
    I'm not loosing any coolant though? So the compression test won't show anything, or do you think it will for another reason?
  28. #27
    1,877
    Do it every 6 months then, I change my oil around April and then again in October, never had a problem with mayo on the cap.
  29. #28
    Dec 2012
    231
    Do you do a lot of short journeys mate?
  30. #29
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    137
    Just noticed mayo under my oil cap for the first time, tiny bit on the end of the dipstick. My drive to work is only 6-7miles and car is only often used for short journeys, going to give it a blast out next week & an oil change...*fingers crossed*
    Ibis S3 8P3 - Airlift V2 / S63 AMG wheels / RS3 Grill / Recaros
    Previous: Polo 6n2 20vt / S3 8L GT28
    Instagram: @bradraistrick
    http://www.audi-sport.net/vb/a3-s3-s...s3-thread.html
  31. #30
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    568
    Quote Originally Posted by br20vt View Post
    Dirty coolant? Excessive smoke out the exhaust? If not, then don't worry.. Just needs an oil change.
  32. #31
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    137
    Quote Originally Posted by chris.vincent3 View Post
    None of them mate, coolant is clear & no smoke :D Must just be the amount of short journeys ive been doing lately.
  33. #32
    Dec 2012
    231
    I did a decent journey in mine, it cleared most of it, then did an oil and filter change as well as an engine flush, clear as a whistle, I've done a couple of short journeys this last 2 weeks and there's some building up. So it's just a character of the engine if you do short journeys, but I'm happy knowing my oil and filter are brand new.
  1. Just received a used K03s. how much is too much play in turbo?
    By takworldwide in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 22:19
  2. how bad is this s3 too much for me
    By a3kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2005, 23:06
  3. How much is too much?
    By kmtam72 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th November 2004, 11:41
  4. Is 21-22k for a used car too much?
    By SonTon2003 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th November 2004, 10:04
  5. Too Much in one go?
    By Banwell in forum Tuning
    Last Post: 31st August 2003, 19:40
