AH FabricationsVolks Autos
Results 1 to 12 of 12
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,070
    Rear shock??????
    Hi all,
    Not sure what its called but my rear shock absorber cover has dropped down and won't stay up the rubber has deteriorated, what can I do to fix this don't really want to fork out for a new shock..
    Can anyone help?
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    Mine has done the same, it's actually an alloy cap on the rubber 'bump stop' that holds the dust cover and has just corroded away, letting the dust cover fall away. The cover is round and the bump stop is oval so it won't simply slide back over and stay in place.
    The only real fix would be to replace the shock, something I keep meaning to do...
    It will work just as it did, but will reduce the life of the shock as it'll be getting covered in cack & wearing down the seal
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,070
    Rear shock??????
    Is there anyway to keep it up shocks are good so don't want to replace? I love no more nails! :-p
    Sep 2005
    Hertfordshire
    99
    Exactly the same here. Shock itself is fine, just the protective cover has fallen down. I keep meaning to tape it back on somehow!
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    Quote Originally Posted by JamesO View Post
    its worth a go!
    I've not tried to hold it up with anything, but that's all it needs doing - holding up to stop the cack!
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,070
    Rear shock??????
    Quote Originally Posted by Boon View Post
    its worth a go!
    If anyone has any ideas on how I'm all ears :-p
    Sep 2005
    Hertfordshire
    99
    I found an old fibre glass kit from the days when I used to patch up my old Montego. I swore I'd never use the stuff again as it's so messy and sticky, but it's worked a treat on securing the cover back onto the cap. I only used a small amount and was careful to make sure it didn't spread out onto other parts. You can get resin/hardner sealants for about £5 which might also do the job if applied carefully. Worth a try maybe?
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    I too have this problem. Fitting new springs tomorrow and was going to try and fix it with either cable ties or maybe a hose clip if I can find one big enough.
    ....................I'll make a build thread one day.
    Aug 2012
    Milton Keynes
    86
    I was thinking hose clips as I was reading all the posts, you got there before me! haha.
    I have the same bloody issue. Shocks dont seem cheap and they are preferred to be changed in pairs. Again my shocks are perfectly fine! Hose clips would be the best bet I think.
    At worse just leave it until the shock gets completely knackered, why replace something good anyways? might aswell wait for it to become knackered.. or simply try and slow down the rate of it becoming knackered
    Quote Originally Posted by MTRL View Post
    Jul 2012
    55
    Just buy a new bracket from Audi its £4.10 or cable tie round the bump stop cable tie round the plastic sleeve cable tie together boooom that's what I've done until I can be bothered putting my ring on properly
    barnzy's Avatar
    Dec 2010
    Essex
    92
    cable/zip tie the cover on if not pop to local car spares shop and grab some 100mph tape (gaffa tape) will hold out... if not get some shock socks like on the quads and dirtbikes
    FOR SALE
    2004 GENUINE XENON HEADLIGHTS GREAT CONDITION
    FULL LEATHER INTERIOR! GREAT CONDITION
    FULL BOSE AUDIO SYSTEM INCLUDING HEAD UNIT (6CD CHANGER)
    FULL ENGINE COMPLETE WITH POLISHED & PORTED HEAD
    BREAKING THE WHOLE CAR PM FOR SPECIAL REQUESTS
    & TO GAIN A CONTACT NUMBER.
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    517
    Cable ties i did mine with on my old car,wasnt greatest of fix but it did the job
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
  1. Rear Shocks??
    By imported_RedSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2006, 11:08
  2. Rear shock removal on A6? any ideas?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th March 2006, 20:39
  3. Rear shocks shot @ 12300 miles....
    By MrLapou in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2006, 15:25
  4. Rear Shocks shot @ 12.3 miles.....
    Last Post: 17th January 2006, 17:59
  5. Rear shocks and bushes
    By t30gue in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 10:41
