Volks AutosMonster Motorsport
Results 1 to 33 of 33
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Coming Home Lights Not Working
    I've just Retro fitted the leaving / coming home lights mod.
    Coded it all in, leaving home works fine, so I assume the wiring side is fine, as it's only one wire.
    Coding wise, I followed the guide. Bytes 5 and 7 are checked, adaptation is set to 30 secs for both.
    The guide suggests they should just by starting engine, then turning off and removing key?
    So there's no minimum time of running before they will activate?
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    295
    Was it dark out?
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Oct 2012
    Warrington, North West
    986
    Quote Originally Posted by monopole View Post
    Was it dark out?
    It doesn't matter if he doesn't have the auto lights, I retrofitted mine a week ago, and found that I had to earth the cable then wrap it up in insulated tape as it seemed to toggle itself off
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: Coming Home Lights Not Working
    Don't have auto lights ^^
    The cable has a proper ring terminal crimped on, which is insulated. So there's no exsposed wire.
    The fact leaving home works, makes me think it's more a coding issue.
    I checked my module, it's high spec one, so that should be fine.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Oct 2012
    65
    Just try activate the additional dis options, did that on mine and they started to work, it gives the option to adjust the times too
    Oct 2012
    986
    Quote Originally Posted by L333fow View Post
    How do you do this mate? What section is it under?
    Oct 2012
    65
    No that I'm not sure on! I don't own vcds I have it done for me! I believe it's in central electronics (where the c/h & l/h options are)
    and into long coder and its either called dis addition features or dis comfort or something along them lines
    Oct 2012
    986
    Ok mate cheers ill have a browse later!
    Fossie
    Rhubarb Triangle
    3,969
    It depends what year your car is as to whether you have got the necessary control module. Look in central electrics for DIS additional features.
    I did Lee's for him and I forget what year his is but my 2006 sportback does not have the same facility. Anything before 2006 has no chance !
    Lee - why did you hit the dislike button on Mikemc's post ???
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Oct 2012
    65
    Didn't know I had actually! Thats what you get for quickly replying on iphone! How do i get rid?Mines 2007
    sorted it! Sorry about that
    Fossie
    Rhubarb Triangle
    3,969
    Nice one Lee - thought it might be a 'fatfingers' job !
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Well mines an 04. Dont remember seeing anything like that.
    I did find an option for something like lh/ch activation 0 = something 1 = something.
    But didnt look like I needed it, more for auto lights or something.
    I'll have a look tom when I get time. But did notice lh didnt work when I went to car after work, but did when I tried it once I was home.
    So I'll recheck the wire just to be sure.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Fossie
    Rhubarb Triangle
    3,969
    Disconnect the wire and see if they work. If they don't then 'flash the wire to earth and try again.
    The system works on a ' toggle on - toggle off ' basis so the wire shouldn't be connected permanently. When it works just tape up the end of the wire and stash it. If you want to turn them off then flash it again.
    Your DIS will not have the additional options so you can't switch them on and off that way.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    So the wire doesnt need to be constantly earthed ? Just earthed once to activate / de activate the system ? Then you could disconnected, and it should remain working as described ?
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Rom View Post
    Yeah - got it in one !
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Right. Disconnected the wire, nothing worked. Shorted it once. Leaving home works fine, everytime I've tried it. Before it had stopped working.
    Coming home is odd, the dipped flick on then off, and sides flash 3-5 times.
    Also side flash when I turn key on after leaving home is active.
    I have t8ps led sides, but no errors on dash, and they work for for leaving.
    Going to try disabling coming home if it's an option. See what that does.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Still at a loss with this.
    Disconnected side lights incase they were the cause, dipped beams fllickered when key removed.
    For now ive disabled coming home.
    But even leaving home doesnt seem to work everytime i unlock the car.
    Wire is now disconnected.
    Any ideas ?
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    The led side will always flash on start up as the car checks the lights. Interested in this as I want ch lh on my 2005 it's starting to seem like its not a goer
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    I done this quite some time ago on mine - the mod. Works for both ch/lh 24/7 as I don't have the light sensor
    If you've followed the guide it should work... Have you checked the timing values in the adaptions? - sorry cant think of the adaption channel off hand
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    It seems hit and miss from what I've read must be getting the coding bang on
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    The coding is the simplest part tbh, you just 'tick' the boxes
    iirc there are two boxes to tick for coming home & leaving home and the one for the light sensor needs to be left unchecked
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Yeah, i originally changed the value for leaving from 60 to 30, but also tried it back to 60 just to check.
    As it is now, ive only ticked leaving, as coming didnt work anyway. But obviously had them both ticked the first time.
    Light sensor is un checked still yeah.
    Ill plug it back in tom and write them down to be sure.
    I did follow the guide, which is why im a bit confused. I just been out to pick gf, unlocked car, and nothing came on.
    Came home, locked it, just tried as i type this, and they came on. Is there a limit, or something ? As ealier i had locked unlocked locked unlocked over and over. Should they come on everytime i unlock ? Or does it need to be cycled, like ignition on to reset before they will come on again etc ?
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Oct 2012
    986
    When opening the car with the unlock button, for me, it will continually activate the lights, but when getting out the car and locking works just the once after turning engine off
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Quote Originally Posted by Mikemc View Post
    Yes mine work just the same
    Have you had any problems with the drivers door? As opening this also activates/disables the timer and turns lights on or off respectively. It may be thinking that the door has been opened?
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    I was trying the coming home with the door open mostly Though i did try it once incase it mattered.
    Not had any issues with the drivers door at all, with regards to locking, window etc.
    I thought maybe i was upsetting it by locking / unlocking so much. And maybe thats why it worked after it had been kind if reset after a drive.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Quote Originally Posted by JamesO View Post
    Ive never noticed this before, though in all honesty, ive never looked.
    But how does it know it had LED? As they should be normal 501 bulbs. I thought the test procedure it done was more based on resistance ? If resistance is out of spec, but is faulty, and error comes up.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
  28. #27
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I think it's because they need so little power.. Mine flash about 5 tomes on start up.. Looks coooool ;-)
  29. #28
    27,029
    That's cold diagnosis for you with led's
  30. #29
    Oct 2012
    986
    Quote Originally Posted by Boon View Post
    The only time my lights go off is when I open the door after unlocking it, or obviously the time elapses
  31. #30
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Think I'm officially beaten.
    I give up.
    Ch will not work, not matter what I do. Lh will work sometimes.
    If I unlock, and it doest work, if i keep locking and unlocking, eventually they come on.
    Ho hum. So much for a simple mod
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
  32. #31
    theo289's Avatar
    Oct 2012
    Bristol
    176
    i've got an audi a3 tdi 2007 sportback - could the leaving lights be coded on this?
    Thanks!
  33. #32
    Oct 2012
    986
    It worked for me on a 55, I'm sure after a certain year it's not so easy? Ill try find the thread I used
  34. #33
    Sep 2013
    London
    Add Topon87 on Facebook Visit Topon87's Instagram Channel
    Does any one no if this product will work on a audi a3, automatic head light kit? TYPE THIS IN ON EBAY!!
    (OEM VW Auto Automatic Headlight Sensor and Controller Golf Jetta Passat EOS
    Watch)
    audi do is part of vw group
  1. Two modifications not working! (Cruise and coming home lights)
    By PhilPD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2011, 23:49
  2. fog lights not working
    By audiquattroowner in forum General Technical / How To
    Last Post: 5th December 2004, 09:37
  3. Reverse lights not working!!
    By imported_richcarthy in forum Classic Audi Forum
    Last Post: 1st October 2004, 14:06
  4. Brake Lights not Working!! HELP!!
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:41
  5. URGENT - BRAKE LIGHTS NOT WORKING!!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2003, 21:57
