Sky InsuranceBadger5
Results 1 to 12 of 12
    MB RS3's Avatar
    Oct 2011
    South East, Kent
    170
    Question Anti-Lift Kits - Big Improvement?
    Hi All,
    What are people's views & experiences with Anti-Lift Kits.
    Is it worthwhile? What is the feel with the kit etc..
    Look forward to your comments!
    Ibis White RS3 - Black Satin Wheels - Black Styling Package -
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by MB S3 View Post
    Hi All,
    I've got the Supaloy kit on mine.
    I don't think it's a huge improvement in the way you would notice changing the ARBs and suspension from stock for instance,but it does make a difference.
    Adds a bit more feel and better turn in but it's not massive.
    Do the other things first,like the ARBs,suspension,and bushes,and then add the ALK or do the lot together.
    JPK
    May 2012
    278
    Made a massive difference to my FWD. Better steering feel, the car feels much more 'planted' on the road and traction has been significantly improved.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,481
    Quote Originally Posted by S3Alex View Post
    would bushes not made it too stiff though? I'm going to fit ALK in next 2 months along with new fuel pump and that could be the right moment to do all in one go but bit afraid everything getting too harsh and unpleasant to normal daily driving.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    The only real unpleasantness i've noticed was that running over cats-eyes is far more harsh in the cabin, other than that only plus points.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by RedDejavu View Post
    I think it depends on what you want.
    The "fast road" bushes are still pretty comfortable as opposed to race ones which are basically solid.
    The same goes for engine mounts.
    I think you'd notice an improvement in feel but maybe a little more vibration as a result but the further you go down the power route,the more noise and harshness you get as a result of uprated engine mounts stiffer suspension and so on.
    Mine is pretty hard as road cars go but it was the only way of getting what was required and sticking with something like what I was running would still give a smooth ride.
    jaydav2306's Avatar
    What kind of upgraded Springs and ARBs do they recommend for the S3?
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by jaydav2306 View Post
    I initially had kW v3s and H&R ARBs,and found that pretty good for road use,with a decent compromise between comfort and performance,but changed recently to kW Clubsport suspension,to get control over front end camber,and improved performance.
    Here's the two together,with the Clubsports to the top,,,,tighter wound,stiffer linear rate springs.
    I wouldn't say this is an easy compromise for road use,as it's pretty hard,but the v1,v2 and v3s are aimed at road use,and there are other alternatives from Bilstein etc.
    MB RS3's Avatar
    Oct 2011
    South East, Kent
    170
    Ok thanks for the reply Alex.
    What do you think the best ARB setup is?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Ok thanks for the reply Alex.What do you think the best ARB setup is?
    Not sure that there's any real difference between Eibach and H&R on the road,but the real thing is they both make a big difference to the way the car handles,by removing a lot of the body roll.
    The S3 is a fairly chunky car at 1500kgs,and on the stock suspension does roll around a fair bit,plus has a lot of inherent understeer,and the ARBs,plus a decent set of coilovers do go a long way to removing that unless pushed hard,but obviously as Ben@AMD had said,I always want a bit more,and it was their job to try and do that for me!
    MB RS3's Avatar
    Oct 2011
    South East, Kent
    170
    I think i may have to invest in some shortly, I've got v1's fitted suspension wise & they made a big difference for my needs. I think a ARB setup will tighten things up nicely. I believe KW do ARB's too? I'm sure this would be a decent choice aswell?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    I don't know if they do,but I would be surprised if they didnt,and they should be fine,whichever you fit.
  1. Whiteline Anti-lift kits now back in stock!
    By AwesomeAl in forum Awesome GTI
    Last Post: 20th September 2012, 16:06
  2. anti roll bar + anti lift kit on s3 8p
    By kevsin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2012, 09:32
  3. Whiteline Anti Lift Kit
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2010, 20:53
  4. Group Buy - Whiteline Anti Lift Kit
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2010, 22:30
  5. Whiteline Front Anti-lift/Caster Kit
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th September 2008, 19:08
