EM TuningJMB Retrofits
Results 1 to 11 of 11
    Sep 2012
    24
    New rear brake pads and steering wheel light's come on - Why?
    Hi all
    I got new rear brake pads fitted today and when I went to pick the car up I was told the ESP and steering wheel lights were showing on the dash. neither light was on when I dropped the car off and the guy told me it must be a dodgy steering angle sensor.
    I didn't argue at the time, but having done a bit of reading it seems it's possible that either they've not pushed the piston back in and/or buggered one of the ABS sensors.
    I now have no power steering!
    Something else strange is that the brake bulb light was showing on the dash (telling me I needed a new brake light bulb) when I dropped the car off, but now the dash light's off and all brake lights work fine!
    It seems way too much of a coincidence that the dash had no warning lights before the pads were replaced (other than the brake bulb light) and now I have the ESP and steering light on...arrrgghhh!
    I'm not an expert mechanic, far from it, so if any of you have advice on this I'd really appreciate your help.
    Oct 2012
    Warrington, North West
    986
    Get t scanned with vcds, where you from?
    Sep 2012
    24
    Edinburgh.
    The guy gave me two codes - 09F2 and 030A. I've googled them but no results. Not sure what scan he did, but find it hard to believe any garage would do a scan out the goodness of their heart for free.
    Dec 2011
    MIDLANDS
    258
    Probably knackered the ABS sensor
    Take it back and tell them they need to fix it as the lights werent on when you took it in!!!
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    Sep 2012
    24
    That was my first thought, but he denied, which obviously he would. I don't understand why that would affect the steering wheel light though?
    I want to get an idea of of what could've caused the problem so I can back up my argument without him fobbing me off. Should never have taken it to a garage I'd never been to before I suppose.
    Oct 2012
    986
    An I right in thinking the date and time will be on a vcds scan of when it first occurred? Wouldn't that show it happened In there hands?
    Dec 2011
    MIDLANDS
    258
    iirc i think the ABS being faulty also affects the ESP which is why the steering wheel light would be on.
    Dec 2011
    MIDLANDS
    258
    as you previously said seems dodgy to do a scan for no reason??
    Sep 2012
    24
    The ABS sensor defo affects the ESP. The ESP light was on about a year ago and a new ABS sensor sorted it.
    So do you reckon it's possible a rear ABS sensor could've been knocked/damaged which has set off the ESP light which in turn has also set off the steering wheel light? Could that then have knackered the power steering??
    Is that possible or am I mental?!
    Sep 2012
    24
    Yeah, sounds like the lights have come on and he thought "sh1t" then checked it out to see what the problem was but he's denying any responsibility.
    I can go and speak to him about it now I have a bit more info, but keep it coming guys if anyone knows anything else that might help...
    Sep 2012
    24
    FYI - my battery had somehow gone flat when it was in the garage. That had mucked up a few ECU settings. The guy who did the brake pads told me to take it to a main dealer and he'd pay for it. So I did.
    Audi did a diagnostic and recalibrated the steering angle sensor and it's all perfect again.
    Happy days...eventually.
  1. Ferodo DS2500 front and rear brake pads
    By downtothebone in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2012, 13:38
  2. brand new audi TTRS/RS3 front brake pads and sensor loom
    By Edition_30_P in forum For Sale/Wanted - Audi Parts
    Last Post: 13th March 2012, 22:50
  3. B5 RS4 rear brake pads - new or used
    By jcb in forum For Sale/Wanted - Audi Parts
    Last Post: 1st November 2011, 11:23
  4. Gap between Rear brake pad and disc
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2011, 11:51
  5. Where to buy rear brake discs and pads?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2005, 20:10
