Chris NottMonster Motorsport
    Mar 2011
    33
    2009 headlight removal
    Hi all,
    How do you go about removing the headlight as my previous post i have the LED runners fault, warranty does not cover it so im going to have to take the headlight out myself and see if there is say a lose wire or a broke ballast etc. I am an electrician so will have minor knowledge but have all the test equipment so i can tell exactly what part is broken.
    Cheers all
    27,096
    Drop bumper of & then you can undo the 2 torx head bolts, that holds the headlight bracket onto the front carrier, then lift out, unplug & have a looksy inside
    Mar 2011
    33
    Wow you have to drop the bumper of to get the lights out! Audi certainly dont like making things simple do they jesus!
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Take a look at the link in my signature mate. That'll show you how to remove your bumper.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
  1. Headlight Removal
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2007, 20:33
  2. Headlight removal!
    By Bridger in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2006, 23:11
  3. Headlight removal
    By blue03 in forum TT/TT-S/TT-RS Forum
    Last Post: 11th November 2006, 08:12
  4. Headlight removal without bumper?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2006, 20:22
  5. Headlight Removal
    By bioharry in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2006, 17:11
