Monster MotorsportVolks Autos
Like Tree1Likes
  • 1 Post By Geraldy212
Thread: Spark plug electrode missing - help
    Mar 2013
    14
    I had the engine management light flickered on my audi a3 2.0 fsi 05 plate for around 10-15 seconds a few days ago when i began to move off from starting the car and then was fine after that and drove fine once, that happened a few mornings but only when it was cold, i called up greenflag to come take a look and they said that cylinder 2 was misfiring and they thought it was the coilpack, so i rang up Audi Main Dealer and as the coil packs had been changed last july they were under warranty still (due to recall 28e9) so i had the greenflag to tow the car to Audi for them to take a look.
    got the call yesterday that apparently they removed the ignition coils and spark plugs and on cylinder 2 when they removed the spark plug the electrode was missing and they suspected it was in the cylinder which was causing the fault, they quoted it would take 7 hours labour to remove, diagnose and reinstall the head and the cost would be 781.20 inc vat just to take a look? thats not neccessarily to actaully fix it just to take a look ????
    ive just gone to pickup the car to bring it home to get another garage to have a look and i go to turn on the car and the car now wont start at all, the coil packs are there but im guessing they might have removed the sparkplugs so that i cant move the car at all, i got the car towed back to my home, but should they have removed all the sparkplugs or done something else so i cant start the car at all ??? is this common practice ???
    they haven't actually showed me the spark plug that is apparently missing the electrode though or anything either
    whats worse is on the final corner home whilst being towed my car hit the car that was towing it and my bonnet has a slight dent in it now which either needs banging out or replacing which im not looking forward too now either.
    Any help or advice would be great
    Sportback owner
    Apr 2007
    France
    464
    Galashan, looks like you had bunch of hurt. First thing is the the garage should indeed have shown you the faulty plug, so demand to see it. Second, they should have not taken the plugs out without telling you. So, here is my suggestion. Take out, or get someone to take out the ignition coils to check if the plug(s) are still there. Then try to find a garage who has a borescope. See this web page for exampe: http://gradientlens.com/? gclid=CND8...FfLLtAod6zsAtg This is an instrument that can be inserted into the number 2 cylinder sparkplug hole, and allows the operator to see inside the cylinder. Perhaps the sparkplug electrode is still in there, or perhaps it has been blown out of the exhaust valve. Also, the operator will be able to look for any damage to the piston and/or cylinder walls/ valves or injector. From that examination, it should be possible to work out the next step. If there is no damage, and the electrode is still bouncing around in there, it may even be possible to remove it through the sparkplug hole. If there is no damage, and no electrode bits, then perhaps you could risk a new set of plugs and start her up. But first get this confirmed by a good engine mechanic. Best I can do. Good luck.
    autolatry likes this.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,158
    I agree with all Geraldy212...
    Mar 2011
    Cleveland
    867
    The bit of plug electrode probably blew out of the exhaust. Happened often in the old days, rare now though.....
    If it was doing any damage, you would probably have heard a light tapping.
    26,720
    I wouldn't even contemplate starting it, until confirmed its empty as such, do as suggested.
    Aug 2009
    833
    happened to me on my bocanegra. complained at garage and they replaced the engine under warranty.
    I know this is not much help but just thought i would let you know that you are not the only one.
  1. Oilly seats :( Spark Plugs Help
    By Grazam in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2012, 16:25
  2. Help needed: Changed spark plugs now car won't start
    By MG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2011, 13:11
  3. spark plug help
    By gussyldr in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 22:02
  4. Help with Spark Plugs
    By Paul Laird in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2010, 21:12
  5. SPARK PLUG HELP
    By m444ty p in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 23:20
