EM TuningChris Nott
Thread: S3 gearbox oil
    Nov 2011
    57
    S3 gearbox oil
    Hi guys I will be putting my gearbox back into the car this weekend after removing it for a clutch and to have the input shaft bearing replaced which meant draining the oil.
    Is it worth upgrading the oil or just put in oil from Audi which is fully synthetic and obviously what they use when they do changes.
    26,721
    Just use the normal oil, which is already very good anyway.
  1. Gearbox oil and brake fluid
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th February 2006, 21:32
  2. gearbox oil
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th November 2004, 23:23
  3. A4 Diesel Quattro gearbox oil
    By QuattroChap in forum Diesel forum
    Last Post: 8th June 2004, 21:17
  4. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  5. S3 Gearbox Oil for ridding Notchiness
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2003, 22:24
