Volks AutosMonster Motorsport
    Joeeey's Avatar
    S3
    Mar 2013
    Rotherham
    15
    Idle rev low then high?!?!?!
    Afraid to say guys that my first post on the site is with a problem!
    ive noticed that when i let the car idle it is lower than normal and sounds like its about to cut out, then it revs up on its own to about 250,000 revs and then drops back down and keeps doing this :S
    sounds like it might be a leak on 1 of the hoses but im no expert!
    just wondering if anyone has has this problem and if they can point me into the right direction?
    Cheers guys!
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Probably not the first thing you want to read when coming to the site for help but use the search feature. Seriously it is a life saver! Welcome to the forum.
    Jan 2012
    SW London
    794
    What car du have? I'd love to see if rev to 250000 rpm lol. Jokes aside, it could be a number of things. If its a diesel with a dpf it cud be running thru a regen. Could also be a fault maf or lambda sensor. Could be many things, under what conditions does it normally happen?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Yip check hoses for leak. Also the oil filler cap and dip stick are properly secure.
  1. Accelerate jerky, idle rev up and down but not MAF issue
    By flippy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2013, 21:51
  2. Revs Low during Idle?
    By Wizza in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2012, 00:00
  3. Coolant low Oil high!
    By mhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2009, 10:33
  4. Idle Rev Playing Up
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2009, 16:05
Tags for this Thread
