Monster MotorsportVolks Autos
Results 1 to 9 of 9
Thread: battery?
    Feb 2013
    77
    battery?
    are these any good need a new battery but not paying 120quid
    096 Enduroline Car Battery 75Ah 700CCA - Car Batteries - Enduroline Car Batteries
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    VCDS USER
    Feb 2013
    77
    i only linked that one because when i put my car in it said that was a upgrade lol and its a 2004 audi a3 140tdi is that a good one then?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    That's the battery praised by many members of this forum for our engine. I am fitting mine this week.
    VCDS USER
    Feb 2012
    Birmingham
    137
    I got the e44 from tanyabatteries. Very fast delivery and local shops by me couldnt even get close to thier prices.
    Feb 2013
    77
    nice might have to order one then?
    Oct 2012
    139
    Quote Originally Posted by Best84 View Post
    Can I just second this. Got mine from them last week. They supplied the E44 for LESS than local suppliers wanted for inferior batteries.
    A few tips if you are changing your battery:
    Before you change the battery, park straight with the steering wheel dead ahead.
    The E44 is larger than the stock battery but will require a little bit of shuffling to get it into the correct position. Remember your battery box will actually come apart so take advantage of that. Once I realised that life became much easier! When done just clip it back together.
    When you turn back on the car will start *****ing about faults. Let it settle down for 30 seconds or so then take it for a drive. Everything will clear.
    The one touch window closing & opening will have stopped working. Open each window all the way, and then close it again. You may need to do this a few times. One touch will now work. NB my passenger window remained stubborn but the next time I cycled the ignition I programmed it first time. Some people report it can take a few ignition cycles to work.
    And the car will forget what the time was but not the date! Bizarre!
    Finally, please properly dispose of your old battery by taking it to a council dump. I saw some idiot had dumped one in a local lay-by a few weeks back. May a pox fall on their household.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Just changed my battery to Varta E44. Starting the engine, even when warm takes less than half a second now, it's almost instantaneous. Money well spent.
    VCDS USER
    Feb 2013
    77
    Thanks for the very good explanation! will be ordering very soon
  1. problem with electrics?battery or alternator??
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2004, 20:36
  2. I took the battery out of ny TT and now my radio w
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2004, 19:19
  3. Battery Loosing Charge.....
    By rickquattro in forum General Technical / How To
    Last Post: 14th January 2004, 16:38
  4. Battery Replacement / Auto Electric Windows
    By ozzy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2003, 17:22
  5. Battery Voltage
    By Naresh in forum In-Car Entertainment
    Last Post: 21st January 2003, 19:31
