EM TuningMonster Motorsport
    Sep 2007
    Swindon Wilts
    170
    Rear wiper squirter continually blocking up
    Hi I have an 08 5 door and my rear washer is constantly blocking up like every other day! Using a pin to clear it but assume I've pushed the blockage into it.
    Any ideas how to solve the problem? The jets are brass.
    thanks
    MacrosTheBlack's Avatar
    Mar 2008
    Kent
    204
    Do a search as I'm sure there's a few threads on this problem that may help.
    But basically you should be able to pull the plastic casing around the squirter and bottom of wiper arm off. Then the jet itself you can just pull off too.
    Check water flows ok with jet off.
    Then leave jet soaking in some WD40 or similar, after that get a thin bit of wire (fuse wires quite good) and push right through jet and give it a good clean out. If really bad get a new jet from Audi.
    Sold:Audi S3 (2008 8P2 with upgrades by NHN)
    Phantom Black
    , Bucket Seats, Sunroof, Parking Sensors, FBMFSW, Armrest Phone Prep, Privacy Glass, ILP, FTW, BOSE, RNSE MkII SDS & AMI, Cruise Control, MY11 Folding/Dimming Mirrors, MY11 Rear Lights, Auto Lights/Wipers
    Aug 2012
    i had this....for ages kept cleaning it out, then it would block again.......so bought a new plastic part off ebay - less than £7 if i remember right? Never had the problem since. Do a search, should be easy to find
    Feb 2012
    Birmingham
    137
    I had this issue. Got replacement jet for the stealers and shortly after the whole motor failed. After opening up the motor it seemed like the washer fluid was mixing with grease etc in the motor which was in turn blocking the jet.
    In the end i got a new motor with the suffix E part number from belfast audi delivered to my door. Search ebay, belfast audi sell through there and beat my local dealer price.
    Jan 2013
    159
  1. Ghost rear squirter and tempromental rear wiper A4 B5 Avat
    By scr8pdo in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2012, 19:26
  2. rear wiper motor continued!
    By vorsprung dork in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2011, 20:10
  3. rear wiper stuck
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 15:44
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
