Dad decided to remove his fuses with battery still connected, now will not start...
chris.vincent3
Own a BMW now, HOWEVER I still own VCDS!
UK, Portsmouth
He decided to remove his fuses because his DIS went off, and wouldn't turn back on.. Now the DIS is back, his car will not start. It is a DSG and the P is flashing and will not allow him to move the stick.
Scanned with VCDS and...
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Monday,18,March,2013,23:46:49:02444
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 62 72
76 7D
VIN: WAUZZZ8P56A150995 Mileage: 171310km/106447miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0F0FNN05N
Coding: 0000078
Shop #: WSC 06314 000 00000
VCID: 78F9ADF70BDAC7D819C
3 Faults Found:
19463 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Freeze Frame:
RPM: 1554 /min
Torque: 68.0 Nm
Speed: 23.0 km/h
Load: 35.3 %
Voltage: 14.06 V
Bin. Bits: 11000100
Idle Stabilization: 0.0°KW
(no units): 48.0
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 0.0
18034 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000100
Bin. Bits: 00000000
Bin. Bits: 10000100
Readiness: 1 1 0 0 0
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0023170
VCID: 71EF90D368A09690DE2
2 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
01315 - Transmission Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH17 0260
Revision: 274553 Serial number: 8P0820043M
VCID: 366563CF414EF1A8CB0
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 146
Mileage: 171318 km
Time Indication: 0
Date: 2013.03.17
Time: 00:00:29
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000005407444
Coding: 118A4F01B214100000160000160000000008FE175A0500
Shop #: WSC 06314 000 08192
VCID: 40890517138A4F1861C
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 186
Mileage: 171318 km
Time Indication: 0
Date: 2013.03.17
Time: 00:10:00
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 186
Mileage: 171318 km
Time Indication: 0
Date: 2013.03.17
Time: 00:15:00
Freeze Frame:
ON
Voltage: 11.95 V
ON
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 003620065SNU
Coding: 0071612
VCID: 428D0F1F1D865D08778
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0011112
VCID: 418F0013188046106E2
Part No: XXXXXXXXXXX
Component: E0221 H03 0080
1 Fault Found:
00002 - Transmission Control Unit
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0420
Revision: D06 Serial number: 2240FD06009869
Coding: 0000413
Shop #: WSC 00011 888 96745
VCID: 377B6ECB464408A0D06
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 165420 km
Time Indication: 0
Date: 2012.10.19
Time: 07:10:36
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 300010611989EA
Coding: 7F3F0F4A07002103
VCID: 2B5342BB8A0CBC40A4E
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 36
Reset counter: 186
Mileage: 171074 km
Time Indication: 0
Date: 2013.03.10
Time: 19:35:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 186
Mileage: 171318 km
Time Indication: 0
Date: 2013.03.17
Time: 00:00:28
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0F0FNN05N
Shop #: WSC 00000 000 00000
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 346159C75732E3B8F54
1 Fault Found:
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D088505489FC63300
Shop #: WSC 00583 210 64856
VCID: 3C7171E77F622BF83D4
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01320 - Control Module for Climatronic (J255)
00352 - Terminal 30A
011 - Open Circuit - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674548345674
VCID: F1EF10D3E8A016905E2
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000688
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D777CE3647822F00AA
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3F3497800
Coding: 0001011
Shop #: WSC 06435 000 00000
VCID: 326D5FDFAD26ED88E78
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 186
Mileage: 171081 km
Time Indication: 0
Date: 2013.03.10
Time: 19:53:05
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 00067824820601
Coding: 0001113
Shop #: WSC 131071 1023 2097151
VCID: 397F68F370501ED0262
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D574CA3B418B270BAA
Deleted the faults then.. Atleast some went away.. :/
Monday,18,March,2013,23:50:27:02444
Chassis Type: 1K0
76 7D
Coding: 0000078
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00000100
Bin. Bits: 00000000
Bin. Bits: 10000100
Readiness: 0 0 1 1 1
Cannot be reached
Revision: 00H13001
Coding: 0023170
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 146
Mileage: 171318 km
Time Indication: 0
Date: 2013.03.17
Time: 00:00:29
Freeze Frame:
Coding: 00062736
Shop #: WSC 06314
Coding: 0071612
Coding: 0011112
Coding: 0000413
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 165420 km
Time Indication: 0
Date: 2012.10.19
Time: 07:10:36
Cannot be reached
Coding: 0000688
1 Fault Found:
000 - -
Coding: 0000688
Coding: 0000012
Coding: 0001011
Coding: 0000144
Coding: 0000144
Coding: 0001113
Where the bleeding hell do I start..
Have you tried a battery reset and checked all fuses. Then id try clearing the faults and a drive cycle, why did he pull fuses anyway?
he said he's tried unplugging the battery and its still stuck in park. Yeah fuses all look fine. Because he thought he would check the fuse for the dash as his DIS wasn't working, why he felt the need to remove all of them is beyond me..
He's either put one back in the wrong place or blown another. Looks like its lost the drivetrain can network.
Should be noted of it was not only his dis working the car wouldn't start as i believe the immo is in the instrument cluster
I'd check all the fuses again and make sure they are in the right places.
i had a look last night and he's missing one for the auto trans, put one in obviously the right amp and still nothing. I'll have another look when I get in, but it's hard to know what he's missing as I haven't seen it before he was let loose in there.
Chris, what I would do now is to go over the fuseboard with a fine toothed comb, and make double sure that every working circuit has a good fuse. Your dad already missed out one fuse, so there may be others missing too. If you put a fuse in an unused circuit, it should not matter. Don't forget there are two fuseboxes, one under the bonnet, and one inside. When it all checks out OK, then do a battery disconnect, short out the battery connections for a few seconds (electronic reset), and then connect up again. With all circuits now live together, there is a chance it will recover and start communicating properly on the can bus. Good luck.
Thanks for the reply, I was thinking exactly that, filling the whole fuse box with correct fuses even if its not needed, as it won't do any harm if there isn't a circuit there.
Is there a right/wrong way to short out the battery? I've not heard of doing that before :-/
Check all fuses and have a look to see if any are blown then get hold of vag com after replacing the blown fuses if any, run a scan and then clear all faults, it should be all ok fingers crossed
Chris, when you simply disconnect the battery, it takes off the 12V supply to all of the car. However, some electronic modules may have capacitors installed that might retain some power. So an easy way to discharge any residual voltage is to touch the connections together, so shorting out any residual power to ground. That at least ensures that you restart from a real zero voltage. Anyway, it can do no harm. Just thought of something..... are you sure that the immobiliser is not allowing the car to start? I believe that you need the key fob correctly registered to the car in order to please the immobiliser circuits. I am sure a forum member can confirm this.
Thanks everyone, tried everything you guys suggested and it now runs and drives. Will find out how well tomorrow when he takes it to work.
A few faults came up after the initial scan but after clearing majority haven't came back, anyone able to give some pointers on how to fix the remaining faults?
Tuesday,19,March,2013,22:39:26:02444
Chassis Type: 1K0
76 7D
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
Coding: 0000078
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 S HW: 02E 927 770 AE
Component: GSG DSG 070 1102
Revision: 04507000 Serial number: 00000601190787
Coding: 0000020
VCID: 2343AA9BE2DC74001CE
Revision: 00H13001
Coding: 0023170
Coding: 00062736
Shop #: WSC 06314
Coding: 0071612
Coding: 0011112
Coding: 0000413
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 165420 km
Time Indication: 0
Date: 2012.10.19
Time: 07:10:36
Cannot be reached
Coding: 0000688
Coding: 0000688
Coding: 0000012
Coding: 0001011
Coding: 0000144
Coding: 0000144
Coding: 0001113
looks a lot like the instrument cluster may be defective, i would try putting the long code back into it. failing this im a bit stuck maybe a new one required. possibly you could get that guy that was flashing the rs3 software onto them to give that a shot see if it sorts it out
