Volks AutosMonster Motorsport
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Is anyone running a decat on standard map?
    As the title suggests.
    On my last car I ran a decat on standard map, and like most modern cars the EML would come on as it sensed a huge rise in emissions.
    It didn't do much really apart from being a annoyance. After testing the power and AFR with the light on I found that it would run a tad rich on WOT/full boost but still boosted spot on and power was better showing good gains.
    I know a sports cat doesn't have this hastle but I just don't fancy one.
    I'm pretty sure the EML would come on as above, however would it still run as my old car did with the light on or would it go into a limp mode?
    I also eventually ran a 90 degree o2 spacer which stopped the light from coming on as it allowed the lamba sensor to sit out of the flow of gases. Anyone tried this?
    Thanks.
    Mar 2013
    Leicestershire
    425
    Also I did search about on here and google but came up with nothing relating to the S3 8P.
  1. Anyone running a N75 J valve on mapped S3?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2008, 18:31
  2. Anyone running or had any experience of the Spax RSX coil-overs?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2005, 18:08
  3. Anyone running 18" RS4 reps on your B6?
    By imported_ZeroK66 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2005, 09:38
  4. So anyone running on yellow sports Konis?
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2005, 11:26
  5. Anyone running a T28, GT28 or GT28RS?
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2004, 19:29
