Results 1 to 22 of 22
Thread: 2.0T FSI SPORT
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    2.0T FSI SPORT
    Hi, I've just bought a used A3 with DSG. It has full service history, it says the cambelt was last changed at 60k - it's now at 108k. I've booked it in to get done on Wednesday, there's nothing in the service book that mentions the DSG service. Should I assume this hasn't been done also? What parts do I need to do that? Also the temp gauge likes to fluctuate between 70 and 90, I've read online that this could be considered normal but it doesn't seem right. Last question is I have the Concert single DIN stereo with no CD changer, what is the best way to make this functional with an iPod? Thanks
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    2.0T FSI SPORT
    I can help with the temperature I have the same engine and mine did the same, common fault with the thermostat you new one about 35 quid a pain to fit, it's a good couple of hours work.. But it will run much better after
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    If doing cambelt, which I'd advise you do, have the water pump changed at same time, and since coolant system is being drained, for good measure, renew the thermostat.
    Yip def have DSG oil and filter changed. Requires 5 litres of DSG oil plus the filter element costing about £80.
    Also consider renewing the HPFP cam follower.
    Jan 2013
    Bolton, UK
    402
    Cheers, do you have the part number for the thermostat by any chance? There seems to be a few different ones and I'm unsure which I need, thanks again
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Quote Originally Posted by MrLapou View Post
    +1 and would recommend doing the DSG oil every 40k miles as a minimum
    I inspect my cam follower every 20k miles. My cam follower was looking mint at 80k miles but I replaced it at 100k miles as it showed some signs of wear.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    2.0T FSI SPORT
    Quote Originally Posted by Aidy06 View Post
    I got mine from eurocarparts although I know alot of people think genuine is better on there it's part number 209440480 28.20
    Jan 2013
    Bolton, UK
    402
    Is there a difference between tip tropic and DSG box? Would mine be the DSG box?
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by _G_ View Post
    How big a job is getting the cam follower renewed?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    2.0T FSI SPORT
    Very simple and low cost.
    If I remember the follower is about £50 and its a job well worth doing especially if you modify the car.
    If it fails it can do a lot of damage.
    JPK
    May 2012
    278
    You will have a DSG as you mentioned you have a 2.0T. The 'tiptronic' box is just a conventional auto.
    You could also try replacing the temp sensor on the right hand side of the engine as a first port of call. It costs stuff all and its a 5min job.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    Oct 2012
    Warrington, North West
    986
    2.0T FSI SPORT
    Quote Originally Posted by JPK View Post
    I was understanding that tiptronic was flappy paddles to change gears thus not being an conventional automatic but a DSG
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Tip and DSG both offer paddle option. Operationally the gearboxes work in far differing ways.
    Do a google and you'll find out how.
    Oct 2012
    986
    2.0T FSI SPORT
    Then which models come with tiptronic?
    I have an a3 2.0tdi DSG but the owners manual states tiptronic, I just thought DSG was VW's branding and tip/s tronic was audis
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    291
    With tip tronic, you wont get the conventional rev needle climb/drop as it goes through the gears, it will be one continuous sweeping motion (it will usually try to hold around 2000 rpm unless you boot it), tip tronic and s tronic(DSG) are totally different technologies
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Oct 2012
    986
    2.0T FSI SPORT
    I thought s tronic was the new 7 speed?
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    291
    No. S Tronic is audis name for DSG
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    the double clutch arrangement (S-tronic is same as DSG) comes in 6 speed and 7 speed dependant on engine.
    older cars from about 2003 are 6 speed.
    Jan 2013
    Bolton, UK
    402
    Having trouble locating a cam follower, Eurocarparts doesn't stock them. Anywhere else that will sell them? I'm guessing Audi will but I'm also guessing they'll be expensive? Thanks
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    TPS or Audi with this type of part Europarts wont have it, dont think its expensive from audi anyway less than £50 anyway
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    think about £25 from audi or vw. it's called the plunger on the parts list.
    Jan 2013
    Bolton, UK
    402
    Thanks, I'll let the guy know that's got my car and is carrying out the work
    Jan 2013
    Bolton, UK
    402
    Just ordered one form OEMparts.co.uk
    £28.95 delivered, will try my hand at fitting it this weekend. Read all the guides I can find and it looks pretty straight forward, hope it has been changed in the past as the car is on 109k miles now. Dread to think of the damage if it's never been changed
  1. Audi 2.0 FSI Sport - Air Con Problem
    By Gogs-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2009, 12:40
  2. A3 2.0T FSI SPORT QUATTRO
    By stone100381 in forum The Welcome Section
    Last Post: 31st July 2008, 18:54
  3. Any Feedback on A4 2.0 FSI Sport?
    By arayet in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd June 2007, 22:13
  4. Audi A3 2.0 FSI Sport
    By ronakc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2007, 09:40
  5. A3 2.0T FSI Sport DSG/Quattro - no Dual Exhaust?
    By schem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2004, 12:14
