    Nov 2012
    47
    How to bleed clutch
    Audi a3 sportback 2007 plate 2 litre tdi. Anyone know how to bleed the clutch. My friend tried it today but the pedal still feels soft and he said the brake reservoir keeps taking in air so it's flooded with it and I'm left with soft pedal. Anyone know what's causing this. My friend said he will try a new pressure bleed bottle he has ordered and fingers crossed will cure the problem. Anyone had this issue and tell me the fix please..
    Nov 2012
    47
    Quote Originally Posted by dawudbhai View Post
    Anyone bump bump
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Bleeding clutches is a pain in the ass usually. If they have been left empty, or a component changed can take a while. A pressure bleeder wont always do the trick. You can try pumping pedal, then holding down, then undo nipple, do it up, pump again etc. I often end up taking nipple out, and just pumping pedal till fluid starts to spurt out. Then pressure bleed it. Messy, but generally works, and faster too.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
  1. Query - how long do clutches last for
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2011, 12:04
  2. Bleed Clutch slave cylinder
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2010, 12:57
  3. Bleeding Clutch System
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2007, 12:32
  4. How to bleed using VAG-COM?
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2006, 17:23
  5. Bleeding Clutch
    By imported_rashpal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2005, 14:23
