Monster MotorsportVolks Autos
Thread: brake bulb type
    Jul 2011
    217
    brake bulb type
    As above I have a rear brake light out. Got the warning on the dash so popped to local auto shop and looked at the list and saw I needed a a 382 bayonet bulb . got home removed the light cluster only to find the bulb is wrong. Am i right in thinking that its the top bulb in the cluster for brake light? Also what type is the bulb looks like a big 501 wedge type bulb to me . thanks
    Fossie
    Rhubarb Triangle
    3,969
    Jonny, you need to give car details, year etc. Audi change things a lot !!
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Jan 2012
    SW London
    794
    brake bulb type
    If its an 8p1 or 8p2 then 382 is correct. If its an 8p3 or uve retrofitted the led rears then u need a 955. But make sure u get the correct bulb, there are 955s available as 16w or 21w and i know most the VAGs run the 16w. The original is a toshiba bulb so see if u can find some of those
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    27,114
    Usually the bulb type is indented into the metal part or imprinted onto the glass.
    Jul 2011
    217
    Yeah sorry its a 8p3 and it was a 955 bulb I couldn't get the Toshiba one so I got a Bosch one from halfrauds cheers guys
  1. Numberplate light bulb type
    By Andy_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2009, 19:31
  2. Bulb types - Interior Lighting A3 Facelift
    By sparx in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2008, 17:18
  3. HOW TO: Replace rear brake bulb?!
    By JCC1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2006, 12:03
  4. Fookin brake bulb
    By leespears1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 18:36
  5. Bulb type
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 12:19
