Can anyone help with this? I had the fuel pump changed on Wednesday as the car kept going in and out of limp mode. Ever since then the interior has smelt quite strongly of petrol. I called the Audi garage who said this is normal and should dissappear in a couple of days. However every morning it smells stonger. I've left the windows down all day today to air the car, and removed the base of the rear seat where the smell seems to be the strongest.
After removing the seat there was a clear smell of petrol coming from the fuel pump housing so I wiped the surface of this and all around the rubber seal with warm soapy water. However, the seal on one side of the housing (shown in the picture) can be lifted up creating a stronger smell, whereas the other side of the seal fits tightly and canât be moved.
My guess is therefore that this rubber seal is not sitting tight and fumes are entering the car through this, but Iâd be surprised if the seal is the only protection between the tank and the car interior. Does anyone know what sits beneath the seal, and what the garage should be checking when I take it back to them? Or is such a smell normal after a fuel pump replacement?
Thanks all.
Thanks all.
