Sky InsuranceChris Nott
    Feb 2013
    13
    2.0TDI Rear Left ABS Speed Sensor...
    Hi Audi Sport,
    Been lurking for a while but finally needed an answer on something..
    I've had my car scanned and it is showing the rear left ABS speed sensor has an error/is broken.
    I read that it could also be other things but I've looked on ebay and sensors look cheap enough so Il try that it first. I just need to know which one I need!
    I had a quick peek under the car when my mechanic had it up and it looked like this one...
    Bosch Rear Right ABS Sensor Genuine Brake Wheel Speed Sensor New | eBay
    But there is also these ones knocking about on ebay which are a lot cheaper
    ACP Rear Left ABS Wheel Speed Sensor 'Trade Price' Direct Replacement New | eBay
    If anyone could help me here it would be a great help!
    26,730
    Are you positive its the sensor & not wiring or the bearing/abs ring.
    I would try swapping round temp to see if the error clears, when its confirmed, then change the sensor if need be.
    They share the same wiring connector afaik, so even just plugging it in to the connector should be enough to remove the error, it may display a different error afterwards if it needs a drive, but as long as it shows no actual sensor comms error then this should prove sensor, wiring or bearing/ring, worth a shot.
    Jan 2012
    14
    Iv just had the same problem but when I scanned mine it said mechanical fault did yours say the same. If so you need to replace the hub as the abs ring is nakered make sure to get the right one as well because there's two a 32mm and a 30mm. If it said electronic/electrical fault then its more than likely the sensor.
  1. Audi a3 2.0 tdi ABS Wheel Speed Sensor; Rear Right (G44) Implausable signal
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 21:04
  2. A4 B5 Front ABS/speed sensor.
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2010, 11:29
  3. **READ ME** ABS wheel Speed sensor.....WARNING!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 14:01
  4. Rear ABS Wheel Sensor fault reported
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 18:32
  5. ABS Throwing fault Wheel Speed Sensor
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2009, 15:15
