Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Geraldy212
Thread: Inlet manifold cleaning will it increase power ?
    TDI140's Avatar
    May 2011
    1,365
    I was watching a few videos on youtube and many old school tuners say removing and cleaning the intake manifold is a good way to rediscover lost BHP is this true ? I would like to have a go at this as my car has slowed down quite a bit after running on bentley rims, so i would like to know if anyone has done this and if its worth the hassle ? Also a guide on how to do this
    thanks
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    tdi-man's Avatar
    Jul 2009
    1,612
    ive had mine cleaned as they do get dirty but not sure about the power increase might make air flow better
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    TDI140's Avatar
    May 2011
    1,365
    I was thinking about buying one from a Breakers yard an having it shot blasted and cleaned then powder coated into forge red and then taking mone off changing the gaskit and having egr delete done and selling my inlet manifold shot blasted red aswel could start a trend off
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Have a look at camcoats website regarding inside painting. They did a cracking job on my Ducati exhaust.
    Camcoat Performance Coatings - Specialists in Exhaust Coatings, Ceramic Coatings, Piston Coatings and Thermal Barriers
    Sportback owner
    Apr 2007
    France
    497
    TDI140, I would have thought that if there was any serious restriction of the inlet manifold diameter, then cleaning would be useful. However, our TDI 140's don't seem to me to gulp a great deal of air compared to, say, high performance and very high reving petrol engines. Take F1 for example. I bet their inlet manifolds are ported and polished to mirror finishes and then some. Nothing wrong in having a go, and see if it does make a difference.
    N8 likes this.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Lewis583's Avatar
    Mar 2010
    872
    Removing and cleaning the inlet manifold won't increase power over standard.
    But it will restore the current power to standard and help with engine smoothness, you will only see a big difference if the manifold is really gummed up.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    27,129
    TBH the manifold can get, in some cases, up to half an inch of crap built up, so yes it can affect airflow to a degree, as advised it can only help get a standard flow, so maybe if the car was bought 2nd user, you may notice a very tiny difference, but only doing will tell.
    I'm taking mine of shortly to clean anyway, as upgraded a hell of allot of things in the mean time, so want optimal
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    What other things can you do to bring your performance / power back up if its lost a bit over the years?
    Besides new oil, filters, plugs etc.
    ....................I'll make a build thread one day.
    Jul 2010
    Merthyr Tydfil, United Kingdom
    884
    Quote Originally Posted by MTRL View Post
    renew and replace all boost pipe seals and clips; maybe even pipes if the lugs are worn
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    TDI140's Avatar
    May 2011
    1,365
    Some good advice asn members i may have located an inlet manifold close to where i live so might check it out tomorrow and all being well ill clean it so its like new and give it in for powder coating in dolphin grey or forge red to match my hoses, i personally recommend installing a catch can as ive noticed a smoother drive and power output through the gears, ive just replaced intercooler and had all boost pipes taken off and washed before refitting, and end of this month its going for MOT and back box delete so hopefully i will see results,
    btw does anyone know if running bosio 1287+ injectors on a stock turbo will show decent power increase as i cant find anyone who has done it
  1. Replies: 2
    Last Post: 20th December 2012, 23:26
  2. How To Clean Your TB And Paint The Inlet Manifold
    By 16Klappe in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2011, 13:09
  3. EGR and Inlet Manifold clean
    By QuottroA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th March 2010, 15:52
  4. Inlet Manifold Cleaning
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th August 2008, 21:11
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
