Volks AutosChris Nott
Results 1 to 9 of 9
    Oct 2012
    Warrington, North West
    986
    Help with passenger window issue
    I coded in coming and leaving home lights, using this guide, http://audiretrofit.quinlivan.net/cominghomelights
    Now it only works when I don't have the repair wire fused so basically never even needed it?
    But now I'm getting a problem with my passenger window, it will go down using the drivers side control but won't go back up, goes back up using the passenger door control though, any thoughts?
    Fossie
    Rhubarb Triangle
    3,969
    Mike, you did need the repair wire but it's a 'switch-on/switch off' connection so if you flash it again it will disconnect.
    The window problem is unconnected with CH/LH lights unless you messed up with something else !
    Do basic settings again in VCDS to find the problem and (hopefully) fix it !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Oct 2012
    986
    but the CH/LH lights never worked when the repair wire was earthed, only when i un earthed it?!
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Mikemc View Post
    Like I said - 'wax-on/wax off' ! You just have to take the bare end of the wire and touch it to earth. Doesn't need to stay connected. If you take the bare end again and quickly flash it to earth it will toggle the lights off.
    Oct 2012
    986
    slightly confused there mate, what shall i do?
    Fossie
    Rhubarb Triangle
    3,969
    Go into 'Passenger door electrics (or whatever) in VCDS and start doing output tests. That should reset unless there are other problems.
    If no good try 'drivers door electrics' with basic settings
    I assume we are still talking about resetting the window not ch/lh ?
    Oct 2012
    986
    well i meant both, i dont understand what i need to do with this repair cable?
    Fossie
    Rhubarb Triangle
    3,969
    Just tape up the end of the cable and leave it where it is. You will only need it again if you want to switch off the ch/lh facility.
    Oct 2012
    986
    Ahh I see thanks mate
  1. Help with my clutch issue....
    By OllieH in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2012, 20:28
  2. help with a few issues please guys
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2012, 17:44
  3. Help with passenger side electric window and door light not working!
    By BarryM in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th September 2011, 15:22
  4. Help With TT Window Closure
    By makavelli in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd September 2009, 15:57
  5. new user help with elec window control
    By imported_kenloen in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2005, 08:12
