Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Fitted JOM coilovers today
    So today was my last day of annual leave to use before April. What better way to spend it working on the Audi....
    Anyway started about 9 this morning and got finished by about 12-1ish can't really remember. Not done anything like this myself before but with a little help and the odd phone call to a few mates I got there.
    The rear sits slightly higher that the front. I'm going to leave it for a couple of weeks to settles down then re adjust everything until I'm happy and get tracking etc done. Im going to Belgium, Brussels in it next week with 4 people so cant go any lower yet anyway.
    The ride is certainly a lot harsher but it's actually not too bad. I have played around on some roundabouts and have slight rubbing on the front. Also slight scraping over speed bumps.
    Looks mich better though.
    Dec 2011
    233
    Looks good mate
    tdi-man's Avatar
    Jul 2009
    1,609
    may have to remove the inner wheel arch screws and rubbing may stop
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Yeah I think I might have to. The rears have loads of clearance at the moment as they aren't particularly lower yet. The fronts have dropped by about 30-40mm not to sure really lol just guessed and put them on. The front slightly catches where the arch liner screw is.
    I know you can get away with removing the rear screw but is the front screw safe enough to remove without the inner arch flapping about?
    tdi-man's Avatar
    Jul 2009
    1,609
    yes i had to take mine out if i remember rite its just the top 1 on front u take out
    and 1 from each rear
    Mar 2013
    21
    Looks good!
    Cheers Paul
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    I've done about 400 miles now with the coilovers on. They've definitely settled more. How do people find with the grounding out. Over speed bumps I'm catching something slightly but back road the camber causes belly pan to scuff.
  1. JOM Coilover Fitted Now Getting A Kncoking Noise
    By Audi-Power in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2012, 10:39
  2. JOM coilovers fitted, knocking noise at front (pics) help!
    By wez3570 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 18:15
  3. JOM Coilovers fitted and ran in
    By Anthony_H in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2010, 11:36
  4. JOM Coilovers
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2009, 20:18
  5. A3 8L JOM Coilovers - 200!
    By DPM in forum DPM Performance
    Last Post: 25th November 2008, 18:49
