AH FabricationsSky Insurance
    Jan 2013
    20
    2.0 BKD - Puff of blue/black smoke on cold startup only
    Right,
    Car is suffering the BKD lumpy idle syndrome.
    So far established DMF on way out as has the odd chatter now and again, but not replaced it yet.
    However, also had timing belt done at Audi a couple of months back and felt much lumpier when retuned. It went back to be checked out and was returned with the cursory "they all do that sir".
    For the last week or so, I've started getting a puff of smoke on cold startup that dies not look good. After initial start, no smoke at all. No new noises, no loss in performance. Also, no smoke when started warm, or when started after being left at work all day, only smokes when left overnight (c.13hrs).
    Could it be just that the fuel timing is slightly out and Audi fobbed me off, or is it another common fault I have to look forward to?
    How can I go about diagnosing the fault?
    Mar 2011
    Cleveland
    979
    Sounds normal to me, mine does it.
    27,093
    Yes same issue I had, for 2 years lol, timing was out by a tooth or more on each side, unreal didn't damage anything, puff of smoke in morning, roughish start, worked like a charm all day, colder mornings was worst of course with more smoke, I reckon they didn't lock it in place when changing, so take it back, demand its redone with locking pins.
    Mine was changed by selling garage, not audi, recent change was done by mastertech friend of mine, to the letter, bang fixed numerous issues I had, well happy.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Yeah, mine does that too after longer break.
    VCDS USER
  1. a3 2.0 tdi BKD 2004 smoke problem blue/black
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2012, 23:51
  2. Puff of blue smoke
    By Jama665 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2011, 11:07
  3. fixed turbo prob, lots of black smoke now won't start! help!!!!
    By shufti in forum General Technical / How To
    Last Post: 30th May 2006, 15:34
  4. Replies: 2
    Last Post: 10th November 2005, 13:40
  5. Replies: 2
    Last Post: 30th July 2005, 01:51
