EM TuningBadger5
    ARH
    Dec 2012
    117
    Upgrading my bulbs..
    Hi all.
    I have recently purchased myself a A3 but I'm wanting to upgrade my bulbs as the standards are so dull.
    I don't want them to be illegal and I don't want them to be too bright and definitely not blue.
    Can anyone tell me what bulbs I need to replace and what colour or spec etc? Or if a HID kit will be better then which one would you recommend, is it easy to fit?
    The car is a 55 (8p2) 1.6 fsi if that makes any difference.
    Any help would be appreciated
    Fossie
    Rhubarb Triangle
    3,969
    Osram nightbreakers or Philips Diamond vision
    Only fit OEM xenons (HID) otherwise you will blow your wiper motor !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Feb 2013
    75
    If you are going down the Xenon route then avoid the non OEM kits, they very regularly blow your wiper motor (£300 down the drain).
    I had a HID kit in my car when i bought it, the chap i bought it off had done some wizardry with resistors and wires to limit the current spike which kills the wiper motor, however, the OEM halogen lenses are not designed to 'control' this amount/type of light, and end up spewing it all over the road (blinding other drivers).
    You can always go down the route of OEM retrofitting either single or bi xenons (these will not blow your motor).
    I would highly recommend a bi xenon retrofit if you have the money spare (over £1k), but if you're looking for a quick/cheap solution, then mike's suggestions are pretty good:
    Osram night breakers
    Philips diamond vision
    ARH
    Dec 2012
    117
    Don't think ill bother with the hid route, I think I will go for the Phillips
    What about my fog lights, indicators etc?
    Aaron
  1. Upgrade Headlight Bulbs Group Buy
    By Tyler Owen in forum General Automotive Chat
    Last Post: 3rd March 2010, 21:19
  2. Upgrade headlight bulbs?
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2009, 19:37
  3. Upgrading headlight bulbs (any advice?)
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2009, 01:11
  4. Upgrading Headlight Bulbs
    By phill1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 07:51
  5. upgrading headlight bulbs
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2005, 12:38
