Volks AutosBadger5
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By NHN
Thread: Chirping noise
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,209
    Chirping noise
    Hi guys,
    This morning my car is making a chirping noise when driving that's comming from the right front of the car, any ideas what it could be?
    Gets worse when turning right.
    Did spend all of yesterday launching the car, maybe this has done something?
    2006 Tdi a3bad 2.0 sportback
    27,089
    Chirping noise, maybe a bird you ran over is crying out, I'm stuck
    Well could be a belt tbh, but try spraying some wd40 on the aux belt see if it goes.
    sliced likes this.
    sliced's Avatar
    Jun 2012
    1,209
    Looool poor bird never stood a chance
    sliced's Avatar
    Jun 2012
    1,209
    just WD40'd the belt and did some hard braking. Seems to have gone now
    sliced's Avatar
    Jun 2012
    1,209
    Probably did a few too many of these
    27,089
    1st thing in morning see if the noise comes back when cars idling on drive, if so, don't drive the car, leave running & again spray some wd40 on the belt & see if it goes, if so, then its either belt or tensioner.
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Or the alternator clutch pulley
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    sliced's Avatar
    Jun 2012
    1,209
    Cheers will check if noise is still there in the morning!
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Or a little stone stuck between disc and backplate.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Chirping noise
    I've got this same issue. Sprayed wd40 on the belt and it stopped. Not sure for long though. It's only doing it around 1000-1200 revs. Did you ever get yours fixed?
    sliced's Avatar
    Jun 2012
    1,209
    erm something similar happened before and it turned out to be warped brake discs?! got all the pads and discs replaced. Now again, a similar chipring noise.
    Sprayed some wd40 and did some harsh braking, so not sure what it was but the noise is now gone
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    imho using an oil like WD40 not good as it attracts dirt to stick. Perhaps a dry silicone spray would be better.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    After some looking about on the web it seems to be an issue with the alternator pulley. I'll check that in a bit!
  1. Audi a3 2.0 tdi(2004)- screeching/chirping noise from engine?
    By Weechris90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2012, 07:27
  2. Engine "chirping" noises on startup
    By speedicar225 in forum General Technical / How To
    Last Post: 30th April 2009, 18:04
  3. Chirping engine noise on startup.
    By speedicar225 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 13:00
  4. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
  5. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
