Sky InsuranceChris Nott
Results 1 to 7 of 7
    Feb 2013
    54
    My New 8P S3 has arrived! :)
    Hey, so after getting some great advice on this forum, I finally went and bought myself an S3. I'm looking forward to going out for a long drive today!
    I had a couple of questions about the clutch. The car has only had one owner and only 30k miles so I'm really hoping what I'm about to ask isn't an issue!
    Firstly, when pressing the clutch pedal, the first inch or so doesn't do anything to the physical clutch, it just feels like the pedal is on a little bit of a spring. If I put a bit of weight on the clutch it somethings pushes it down a little and can therefore give the impression of riding the clutch even though it isn't doing so. Maybe this is just the way the pedal is designed?
    Also, when pulling off from a standstill, if I don't rev the car above about 1300rpm when pulling off, I get slight hollow knocking sound from the engine. It could just be how the car sounds at biting point, but it's different to any car I've had in the past... Hoping these aren't issues! Thanks
    Feb 2013
    54
    Forgot to mention, the car had a new flywheel under warranty about 2 years ago.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,070
    Quote Originally Posted by controlz View Post
    Knocking sound could be the clutch release bearing. From what I understand it doesn't really cause any issues but generally if you were going to change it you might as well do the clutch as well.
    Mine has been doing it since I got it only a little and it's not caused any issues other than being annoying
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Congrats on the new car. Looks a beaut
    Dark Vader Half sibling - MyThread
    XFi
    XFi's Avatar
    Jun 2010
    Grantham, Lincolnshire
    314
    Add XFi on Facebook Visit XFi's Youtube Channel
    Very nice, mine is the same with the engine sound when not revving hard enough when pulling away. It doesn't sound like a release bearing to me but just that the engine is under a bit of load. I've only really noticed it when I'm reversing. I'm pretty sure when I test drove a brand new S3 the sound was also present but I can't be certain.
    Audi S3 8P3 Stage 1
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    Mine is the same and was exactly the same before and after the fitting of a Sachs Clutch with new DMF and CSC so I wouldn't worry about it being a fault.
    My standard clutch from what I remember didn't do what you describe about the difference in pressure through the start of the pedal travel but the Sachs one definetly does.
    Feb 2013
    54
    Quote Originally Posted by bmh.01 View Post
    Thanks bmh, you mean the same as in the hollow knocking sound?
    I wonder why my pedal has a difference in pressure then, and doesn't start engaging for about an inch!
  1. new s4
    By badbaz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2003, 19:48
  2. Seeing as it's New Year what's your calendar??
    By JohnH in forum General Chat
    Last Post: 10th January 2003, 17:10
  3. New Aston Martin V8 Vantage
    By amoffat in forum Other Brands & Models
    Last Post: 10th January 2003, 11:24
  4. This Months Evo new S4 and RS6
    By gabster03 in forum General Chat
    Last Post: 9th January 2003, 21:33
  5. New Blunkpaunt Stereo's
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2003, 14:32
