EM TuningJMB Retrofits
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    P1531/P0333 Camshaft Timing Adjustment
    Over the past few months I've kept seeing the same two codes pop up when scanned. I used to simply clear them and move on, but eventually I decided after experiencing some performance related issues that I should probably not clear them anymore.
    The first is P1531. Below are the scans where I've remembered to save the log before clearing:
    005425 - Camshaft Timing Adjustment
    P1531 - 004 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 57828 km
    Time Indication: 0
    Date: 2012.09.27
    Time: 12:20:30
    Freeze Frame:
    RPM: 5910 /min
    Load: 94.1 %
    Speed: 103.0 km/h
    Temperature: 81.0°C
    Temperature: 32.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.843 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 61792 km
    Time Indication: 0
    Date: 2013.02.11
    Time: 05:24:13
    Freeze Frame:
    RPM: 5167 /min
    Load: 96.0 %
    Speed: 164.0 km/h
    Temperature: 84.0°C
    Temperature: 31.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.716 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 62382 km
    Time Indication: 0
    Date: 2013.03.07
    Time: 18:12:21
    Freeze Frame:
    RPM: 6632 /min
    Load: 77.6 %
    Speed: 83.0 km/h
    Temperature: 86.0°C
    Temperature: 36.0°C
    Voltage: 13.208 V
    The other code I've yet to save, but it had something to do with a knock sensor, P0333 I believe it was.
    I know the first could be related to the N205 valve, but before I run off and replace it I just want to make sure that in the context of the knock sensor error I mention above that the issue does not lie elsewhere
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Try taking out and cleaning/replacing camshaft sensor.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Fault vvt actuator valve by the looks of it, won't be the camshaft position sensor as it isn't complaining about the timing being out of range just that the valve has gone open circuit. Only comes as a complete VVT tensioner unit I believe, not too bad to replace.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by bmh.01 View Post
    Thanks for info. Got a part number and/or DIY for the tensioner?
    Is it the same problematic part as the "cam chain tensioner" people complain about that results in a noisy engine?
    Ex: 1978 VW Beetle
  1. Camshaft variable adjuster seals
    By boomtown in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th December 2012, 08:34
  2. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  3. 2.5 tdi camshaft timing help needed
    By davek in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2011, 15:32
  4. Replies: 9
    Last Post: 26th January 2008, 15:02
  5. camshaft position sensor or timing?
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 11:27
