EM TuningBadger5
    Mar 2013
    14
    Engine Management Light problem on my 05 2.0 FSI Petrol Audi A3 8PA
    Hi im a new member here
    i have just had my engine management light come on my A3, I asked a friend who knows a little about cars and he recommended to start with to disconnect the battery for a while then put it back on and if it clears then the problem isnt serious, so i did this and the light went off, i went to work today and when i got in the car at 10pm i started the car and for around 5-10 seconds the engine management light was flashing and then went off.
    Any ideas as to what could be the problem?
    JPK
    May 2012
    278
    Could be one of dozens of things. You need to get it scanned and find out what the fault code is.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    27,096
    Yeah as above.
    Mar 2013
    14
    ok i have a few codes now if anyone can help with them
    00018
    00768
    00770
    00772
  1. Engine Management Light -INTAKE MANIFOLD PROBLEM????
    By Reiss87 in forum General Technical / How To
    Last Post: 28th July 2010, 12:15
  2. Replies: 5
    Last Post: 16th January 2010, 15:03
  3. Replies: 0
    Last Post: 15th January 2010, 22:01
  4. Replies: 0
    Last Post: 15th January 2010, 16:10
  5. Engine Management Light
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 13:06
Tags for this Thread
