Chris NottAH Fabrications
    rdfcpete's Avatar
    Apr 2008
    123
    OEM S3 Skirts & Sill Inlays
    Guys,
    I'm thinking down the OEM S3 8P3 front & rear bumper route, including the OEM skirts too. No badges of course, just to achieve an OEM+ body look in the most subtle fashion. I intend to retain the OEM Black edition grill surround and grill itself.
    I understand the S3 inlays that come as part of the OEM skirts can't be changed to S-Line ones (like my BE currently has).
    Can they, however, be removed without a fight? Ideally, I wouldn't want the S3 inlays and if I could retrofit S-Line ones that would be my aim.
    The only 3 door skirts I've seen that are anything to my taste are the Votex ones but I want to stay on the OEM path where absolutely possible.
    My cars an MY10 A3 BE 3door and the bumpers & skirts would be from an MY10 onwards S3 too.
    Thanks,
    Pete.
    Pete.
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    944
    You would have to remove the little lugs on the underside of the sill and sand the whole area flat, then you just glue it back on.
    Arjuanamo's Avatar
    4300K
    Apr 2012
    London
    110
    I went down to Chingford Audi yesterday to get all the parts i needed for the skirts,turns out the prices of every part has gone up for some reason.Ended up costing 560 (Trade) for the two skirts,4 door blades,2 end caps and a couple screws. Didn't want to go for the S3 sills as they cost an extra £300 and i wouldn't want S3 badged anywhere in my car.One of my friends said it was a pain in the backside getting the sline sills to fit but is a better option in the end in my opinion.
    Sep 2009
    Trotters, Peckham
    539
    before i purchased the s3 sills, i used my sline and they fit with a little work. did you get the orange inserts to secure the skirts?
  1. A little Audio help for OEM Sub and Amp wiring
    By 4NT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2012, 20:46
  2. OEM Side Skirt Removal...
    By Wozski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2011, 00:15
  3. New OEM Side Skirts to fit B6/B7 on Offer
    By Woorlord in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th June 2009, 08:14
  4. New OEM Side Skirts to fit B6/B7 on Offer
    By Woorlord in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2009, 08:08
  5. fitting oem votex side skirts to my 1.9tdi 2000 a4
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2004, 15:12
