I used Bardahl's EGR cleaner. You need two people for the application; one to hold the throttle steady at approx 2000rpm and the other to spray the cleaner directly into the EGR. Simply remove the hose coming from the EGR and spray directly into it.
It worked a treat too!! Throttle response was instantly sharper and it got rid of the famous PD stutter you get when cruising. My car had only done 45K at the time too!!
My mates garage has just been given the Terraclean franchise or whatever they call it.......first impressions of this system working are very impressive. Clears blocked DPF's and EGR's no problem but your still left with both clogging up again.
Best bet is to just remove & manually clean it, cant get better than that at all, no matter what cleaner you spray into the system.
