Sky InsuranceEM Tuning
    shady-ninja's Avatar
    843
    WHAT SHOULD I DO COZ IT LOOKS LIKE AUDI HAVE COCKED UP.
    took my car to Audi last December coz the clutch was slipping.
    Audi dismounted the gearbox & decided not to replace the clutch under warrantee coz
    it appeared not to be a manufacturing fault then put the gearbox back together.
    2 days ago i tried to use the aircon only to find out its not working.
    did Audi need discharge the refridgerant to dismount the gearbox?
    if they did, then why did they not replace the refridgerant OR AT LEAST inform me.
    prior to this the same dealer changed my compressor under warrantee
    which is less than one year.
    what should i do?
    Lewis583's Avatar
    Mar 2010
    833
    AC shouldn't need degassing when removing gearbox.
    Is the car still under warranty? If it is, take it in.
    If it ain't get the specialist, assuming they have the equipment, to find where the leak is in the system. If its anything compressor related, then take it to the dealer. If its nothing to do with the compressor and the car is out of warranty, they may charge.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. What does your rear wiper arm look like inside?
    By Lewis90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2012, 08:40
  2. Replies: 7
    Last Post: 6th June 2012, 20:59
  3. Looks like APR have sorted the 2.0TFSI OBDII remap....
    By Cupramax in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2005, 11:26
  4. What do you look like?
    By Grant in forum General Chat
    Last Post: 10th June 2004, 17:53
  5. Want to see what a RR looks like?
    By audi_girl in forum Other Brands & Models
    Last Post: 4th September 2003, 18:22
