JMB RetrofitsVolks Autos
Results 1 to 11 of 11
    May 2012
    York
    241
    More turbo lag since having engine recon - 2.0tdi
    Hey,
    I have just had my engine fully reconditioned, it seems now there is quite abit more turbo lag than previously.
    I notice it more in 2nd gear, just nothing then all of a sudden kicks me in the face.
    It was never like this before.
    The turbo blow off also sounds alot quieter aswell??
    Any ideas
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    Was the turbo reconditioned too?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    May 2012
    York
    241
    Nope, no turbo work done at all
    max69vk's Avatar
    Apr 2012
    742
    Check the turbo pipe work is fully secure at the turbo, intercooler & EGR. If the engine was rebuilt these pipes would have been moved/removed & re fitted.
    tdi-man's Avatar
    Jul 2009
    1,609
    what have you had done ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    May 2012
    York
    241
    Had head skimmed, valves recut and seated, block re-bored, new piston rings, new big end bearings and 1 new conrod.
    tdi-man's Avatar
    Jul 2009
    1,609
    just had mine dun as well should be back tomo .
    i had new head , rings , new bearings . full egr delette
    May 2012
    York
    241
    drives lovely bar the lag, it may just be when its cold tbh.
    Would this make a huge difference when cold then?? more lag??
    tdi-man's Avatar
    Jul 2009
    1,609
    um not sure just got mine back today so am running it in cant realy open it up at the moment .
    may just be a loose turbo pipe.
    May 2012
    York
    241
    You dont wanna go really steady when running it in, still drive it meanfully but dont go about 3kish
    tdi-man's Avatar
    Jul 2009
    1,609
    correct
  1. Audi claim to have 'solved' turbo lag!
    By warren_S5 in forum General Chat
    Last Post: 21st September 2012, 20:07
  2. Gear shift turbo lag.
    By pipewerkz in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st December 2004, 02:05
  3. S-Line Turbo - Which turbo does it have????
    By A4T in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th August 2004, 19:52
  4. Turbo Lag
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2004, 17:36
  5. TURBO LAG
    By viper in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2003, 08:24
