Monster MotorsportBadger5
Results 1 to 8 of 8
    sportbacksport's Avatar
    Mar 2013
    Kent
    29
    Remove climate control unit on A3
    Hi need some advise
    I've removed a old handsfree kit in my A3 but have left the bracket till last,it's where the climate control unit is so need to have it out!! Is it quicker to pop the radio out or remove some of the centre console to get to it? Cheers.
    Fossie
    Rhubarb Triangle
    3,969
    Pull the radio out and the climate control unit just hinges down from the top. It can then be pulled straight out giving you access to the screws holding the bracket.
    5 minute job !!
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Mar 2013
    Kent
    29
    Thanks for that,one more thing i've got a concert radio would you know the name of the tool to remove it? Cheers.
    Fossie
    Rhubarb Triangle
    3,969
    Mar 2013
    Kent
    29
    Cheers for that,i had a quick look on the web and found out it needed the PC5-132 version brought on ebay 99p happy days,thanks.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    You can remove the climate without removing the radio, if you have a double-din. Remove the surround around the hazard light/card tray then pull down on the top of the climate unit and it'll pop out.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Mar 2013
    Kent
    29
    I've got a single din.
    27,099
    Don't just pull the climate unit out as the metal spring clips can pop of & get lost down into the console & it can take hours to find again & they're not available as a separate item from audi, remove radio, the card tray & push the clips down slightly from behind before pulling the climate forward, trust e it will save you getting extremely pissed with yourself & the car
  1. how to remove climate control unit?
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2012, 21:04
  2. Climate Control Unit Removal ??
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2010, 18:18
  3. How to remove climate control unit switches/facia?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 12:59
  4. how do remove the climate control unit
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2006, 22:53
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
