Chris NottAH Fabrications
Results 1 to 11 of 11
Thread: Tracking
    Jun 2010
    65
    Tracking
    Hi,
    Just had a new tyre fitted, there was a lot of wear on the inside so got it tracked. He said it was -4 on one side and something on the other that I didn't catch.
    Anyway, now I have to have the steering at about 11:30 for it to go straight and when I leave go it creeps back round towards 12:00. I took it back today and they have checked and said it was bang on. I saw the laser at it was on 0 both sides.
    Before I had the tracking done it felt arrow straight, but the tyre wear says otherwise I suppose.
    What is going on here I don't understand!
    Thanks for any advise.
    Mike
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,164
    Perhaps the worn tyres are not helping. To test, try swapping rears to front.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Re: Tracking
    They tracked it with the new tyres one right..
    Steering off center and pulling is tracking issue. Either in correctly adjusted, or something's bent / worn. But that should show on the equipment.
    Rear toe can also make car pull, did you have just front alignment? Though that wouldn't alter steering wheel.
    The steering wheel should be clamped straight before they adjust, or you can have perfect tracking, but steering wheel can be off.
    Upload a photo of the printout.
    What's the tyre like that was left on?
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Jun 2010
    65
    Yes they tracked it with the new tyre, and I actually tried another one and it is just the same.
    Just the front yes, I think he said he couldn't do the rear? It's a fwd a3. I can't check the other side front tyre now but I will do. I didn't get a print out.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,004
    Go to a place with Hunters equipment that do proper 4 wheel alignment. You'll get a print out so you know exactly what's been changed and by how much.
    This website (Welcome to Align My Car) will find you you're nearest garage that does it.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Jun 2010
    65
    Cheers. None within an hour!
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    518
    I agree with Rom -4 degrees is a fair way out to be honest so they maybe trying to align it with a bent rack arm or something worn and has too much play in it,i have seen many places just bang cars on the ramp and align them to what the car should be without checking if things are straight,so basically they are adjusting the other corners to bring the out of align wheels figures in to the green
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,636
    If you only had 1 tyre replaced, the worn one may be be dragging the car to the side, dependent on the wear. If your worn tyre is below a certain level of wear, the circumference will be smaller than the new tyre and cause the car to steer to that side.
    You're supposed to replace both across the same axle for the above reason, stop skimping and buy another tyre.
    2009 A3 SB 2.0T DSG S line
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    518
    Quote Originally Posted by Artimus View Post
    We also have this a lot at work as we do accident repairs but they cant understand one bald tyre and one brand new one dont work and still insist our repairs or wheel alignment machine is to blame
    Nov 2012
    17
    I have given up having it done in places that use laser and mirrors. 4 wheel computerised is the way to go. Its worth the travel.
    Dec 2011
    Newcastle upon Tyne
    71
    I had a nightmare with mine after ATS "tried" to sort the tracking out after having new tyres fitted. After spending an entire afternoon at their place, the car was near enough undrivable.
    I phoned the lease company and they told me to take it to a main dealer and it's spot on now. The dealer said that everything was out of adjustment - front and rear !!
    MY 2012 A3 Sportback TDi 140 Sport - Ibis White - Bluetooth.
  1. Track Day - 28th Feb @ Mallory Park
    By audi_girl in forum Major UK Events
    Last Post: 24th December 2003, 15:43
  2. Tracking
    By ianmack in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2003, 12:47
  3. Donnington Track Day
    By Joshie in forum Major UK Events
    Last Post: 27th February 2003, 19:07
  4. Tracking Systems
    By Jack829 in forum General Technical / How To
    Last Post: 20th February 2003, 11:54
  5. Donnington Track days
    By Simon in forum Other Brands & Models
    Last Post: 13th January 2003, 15:56
Tags for this Thread
