AH FabricationsSky Insurance
Results 1 to 9 of 9
    Feb 2013
    S3 SPACING AND DROP ADVICE GUYS!!!
    WIETECH BYKW 20MM DROP BACK 25MM FRONT IS THE KIT I BOUGHT,
    BACK WHEELS ARE STANDARD RIMS, BUT SPACED OUT 15MM....FRONT NO SPACING.
    WILL I GET THE CLEARANCE ON THE BACK? PLUS DO YOU REK IT WILL SORT OUT THE REVERSE RAKE!!
    SORRY FOR CAPS DOING A SPREADSHEET IN WORK
    THANKS GUYS
    2010 Audi S3, Rotar Alloys, Flat Bottom Steering, Rns-E, MATT white for the mean time
    jimojameso's Avatar
    Sep 2012
    Surrey
    210
    You might have to change the rear spacers down to 12mm as i think 15's might rub a little. You can try taking the rear screw out the arch. If its a sportback you will have to file the tab down aswell.
    On my sportback i have 11mm spacers on the back and i had slight rubbing on large potholes/bumps but once i adjusted the tab i have no rubbing at all.
    2010 TT RS - Sepang Blue - MRC 420BHP, 600NM
    2010 Stage 2+ S-Tronic S3 BE SB in Ibis White!! ....... SOLD
    Nov 2012
    Essex
    44
    I have 15mm spacers on the rear and 10mm on the front on the standard s3 rims with s3 brakes and no rubbing or issues at all, once lowered the clearance still looks like it would be ok though ?
    Feb 2013
    Cheers L5, what springs you on mate?
    Nov 2012
    Essex
    44
    None yet but will be H&R (as that seems to be the spring of choice if not going the coilover route) and as you can see (well sort of) from the attached picture there is room between the rim and arch even with a drop as they are not totally flush.
    Just thinking though your wheels are a 19 arent they ? If so that blows my theory out of the water ?
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    It all depends on how low you go.
    A lotof people get some rubbing on 12mm spacers when lowered so it can only be worse with 15mm.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    jimojameso's Avatar
    Sep 2012
    Surrey
    210
    I'm on H&R's and it was only on really big bumps i got rubbing.
    Nov 2012
    Essex
    44
    Quote Originally Posted by jimojameso View Post
    With spacers or without ?
    jimojameso's Avatar
    Sep 2012
    Surrey
    210
    Quote Originally Posted by L5 TUW View Post
    With 11mm spacers on the rear. But i have a sportback if that makes a difference.
  1. Help and advice guys accident problem :( .........
    By basspower in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 09:21
  2. BBS CH size and fitment advice
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2006, 15:55
  3. MPG and some advice
    By awebber in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2005, 20:14
  4. Audi A4 1.9 TDI 110 - General Info and Buying Advice Please :)
    By DelBoyUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2005, 12:26
  5. New and need advice!
    By tenbucc2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2004, 03:38
