Chris NottAH Fabrications
Results 1 to 20 of 20
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Problem coding new MFSW - Steering wheel angle error
    Hi Guys,
    Just had a guy come and code my MFSW and CC. CC went OK but had problems with the MFSW.
    The buttons are coded OK but he said it was throwing an error with the steering wheel angle sensor and said he thinks I may have the wrong ECU. The parts I installed were as follows:
    MFSW - 8R0 419 091 FTNA
    Steering Wheel ECU - 8P0 953 549 F
    Air Bag Harness - 8P0 971 589 AD
    I purchased these parts as per the advise given on another thread:
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/181163-2006-audi-a3-s-line-2-0tdi-steering-wheel-upgrade.html
    Can anyone confirm if I have the wrong part or another reason why he gets an error with the steering wheel angle sensor?
    Thanks guys
    Fossie
    Rhubarb Triangle
    3,969
    You have the correct parts. Does the guy who came to code it know what he is doing ?
    The steering basic settings need to be carried out after a change of ecu.
    You should follow these instructions :- VW Golf (1K) Steering Assist - Ross-Tech Wiki
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    If its on MK60 ESP then it just needs the steering taking from lock to lock to calibrate it, the VCDS procedure is only for the MK70.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    I thought I had the correct parts! Thanks for confirming.
    He seemed to know his stuff, he does mobile car audio installations for a living and has used VCDS coding for a while on other jobs. I will see him tomorrow hopefully, so will chat with him about it and show him the link.
    Could the ecu be faulty? They company I brought it from confirmed it was fully working when taken from the car but is 2nd hand still. I have 30 days warranty on it but I need to confirm if it is faulty or not.
    I may take the unit out of the car and re-install just to make sure all is fitted ok.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Quote Originally Posted by bmh.01 View Post
    How do I know if its an MK60 or 70, will the VCDS tell me/him that?
    Sorry but complete knoob when it comes to VCDS.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Quote Originally Posted by JRock247 View Post
    Oh and I have tried lock to lock myself but no change and then drove for a bit and tried again but no go.
    When he had the VCDS on the screen and tried the moving the steering wheel the angle would not change on the screen, if that helps?
    Fossie
    Rhubarb Triangle
    3,969
    Just follow the VCDS instructions in the link for basic settings. There will be no fault with the ECU.
    I had the same problem when installing mfsw and had to go through the process. You may need to do it a couple of times but it will sort it in the end.
    You will have a MK 70
    Good luck and please report back.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Spoke to the guy that did my coding this morning, he said he did try to complete the basic settings on the steering but it would not let him, he tried a couple of times but it would not let him complete the set-up.
    He now cannot come and look at my car again until Friday, which means driving around with very little power steering, my arms are gonna be pumped! lol
    I will take the steering wheel of today and double check everything is still connected up ok and nothing has dislodged. Only have an hour for lunch, so won't take the ecu out as it was a b***h to get out last time but will remove the steering wheel, slip ring and steering angle sensor and re-seat them, just to make sure.
    Is there ANYTHING else is could be?
    Thanks for your help guys, appreciate it.
    Fossie
    Rhubarb Triangle
    3,969
    The process needs to be followed EXACTLY as set out. Pay particular attention to when to switch ignition/engine on and off.
    If you take the slip ring off make sure it is taped first. Presumably your man did this ?
    It can take a few goes so keep at it. I thought I had messed up when I got no power steering but, by carefully following the instructions TO THE LETTER and trying two or three times the steering just kicked back in.
    Needless to say you need to be very careful driving without power steering !!!
    EDIT : also check basic settings in brake system :- http://wiki.ross-tech.com/wiki/index...ctronics_(MK60)
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    When I retrofitted my MFSW, I had a bit of problems with the power steering,
    Mine started working again when I went full left lock for 30 secs then full right for 30 secs, instead of just going from lock to lock straight away.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Quote Originally Posted by leeds2592 View Post
    I only tried going lock to lock. I will try left lock 30secs then right lock 30 secs and what happens. I will report back shortly.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    OK, tried locking each way for 30 secs but no change.
    MikeFoster, I installed the parts myself and yes I did tape down the slip ring BUT it did move slightly when I removed the tape as I knocked it slightly, is that an issue if the slip rings moves?
    Does anybody no anyone in the Hampshie area that can take a look at this for me and give me a second opinion.? I live in Liss, Hampshire but can also travel.
    I have checked out the VCDS Map and messaged 4 people in my area but none of them have got back to me apart from one guy but he is 2 hours away and was hoping to find someone local to me.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    I have done many if these upgrades, and as Mike said, the Ross tech procedure needs to be followed exactly for the Steering module to adapt to your ABS and to also recalibrate the steering.
    Here is a bit of helpful advice, there are different ways people say and tell you to do to get your power steering back, but what I have found which now works 100% of the time for me is, in a quite road, drive the car no more than 10mph then proceed to do a three point turn, locking the wheel completely to the right, and then when reversing, lock completely to the left, then continue to drive the car back in a straight line.
    This should solve your steering angle fault and have power steering back.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Do the 30 second lock each way whilst doing the basic settings with VCDS, it won't accept it after the basic settings have finished calibrating & as said follow it to the letter & it may need trying a few times
    There won't be any thing wrong with hardware - it just needs the basic setting completed correctly
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,388
    as advised, the problem is that the angle sensor needs to be reset. you need to resst the steering angel sensor and the ABS sensor. once this has been done follow those instuctions to the T and it should work. if he still doesnt manage it come to me and il sort it out. done so many of these
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Quote Originally Posted by Dannykn9 View Post
    Tried your recommendation but still no change in the power steering.
    I still have both the ESP Light (orange) and Steering Wheel light (orange) on my dashboard as well.
    I'm not going to see him till Friday now, so will have another go at coding then unless I can find someone else near to me.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    Quote Originally Posted by Ash187 View Post
    OK, I'm going to show the guy this thread and get him to read it over and then we can try coding again on Friday.
    If he still can't manage it, then I will ask for a refund (50%) as I paid him to code both CC (which he has) and MFSW.
    Are you available this weekend and if so, where about's are you located and what do you charge?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Mate, don't waste your time keep trying, it will only work when VCDS is connected and logged in with security settings, but the ABS sensor has to be done at the same time.
    Don't bother about the other bloke, as I doubt he still won't know what to do. Just get someone like Ash to it, or if your anywhere near Reading tomorrow evening, as I will be there doing a couple of cruise installs.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    I've got to give him another try as he is very local to me and I have already paid him to code both the CC and MFSW. I also want to avoid driving far as I have very minimal power steering and tbh, its a little dangerous to drive if I have to swerve quickly!
    I am not in or near to Reading tomorrow, unfortunately. I work from 9-5:30 Mon - Fri, only have the weekends free to get this done really, unless they can see me after normal working hours.
    I'm sure Ash can do it as well, he seems to know his stuff but again, he is in Kent, miles and miles from me.
    If this bloke STILL can't do it on Friday, then I will have no option!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Fair enough mate, but if you change your mind, I will be in Reading around 9 tomorrow evening.
    Good luck with it mate, hope you get it sorted.
  1. Just fitted new stalks/steering wheel now fault codes.....
    By Dan TheMan Welburn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2013, 13:29
  2. Brand new RS3 steering wheel on the Bay
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th December 2011, 21:23
  3. New FB steering wheel for my 2010 1.4 tfsi s-tronic
    By lundoz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2009, 13:21
  4. New S3 steering wheel fitment on 2002 S3
    By ems3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2009, 18:00
  5. New S3 Steering wheel on old S3 ??
    By S£ in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2008, 15:24
