Volks AutosEM Tuning
    Nov 2012
    47
    a3 clutch problem
    hi, my audi a3 sportback 2.0 tdi bkd engine has a clutch fault.
    Just recently, the pedal went soft and would stick to the floor. I thought the brake fluid was low a little, so i topped it up, and all was good for another week. Now, it did it again, where the pedal went soft and the clutch would stick to the floor. I checked the brake fluid and that hasnt moved one bit, so it cant be leaking anywhere.
    Ive checked the external of the car and id assume the internal is fine too. It is driving fine again, but i do remember pumping the clutch pedal 5-10 times and i felt it get harder etc. Its been driving fine now, but i want to correct whats wrong.
    Am i right to think that the master cylinder is shot or is it a more complicated problem.? All help will be appreciated.
    Nov 2012
    47
    bump bump anyone??
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Probably the slave more than the master.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: a3 clutch problem
    Slave is on the box. Master is on pedal / bulkhead.
    You could try clamping off the flexi for the slave, and seeing if pressure is better. But if it's not all the time, may not be easy to find.
    One of the seals if probably leaking internally, so fluid is by passing it, and not pressuring.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Nov 2012
    47
    Quote Originally Posted by Rom View Post
    So it's definitely the slave cylinder and full clutch job? Will I need to replace the master cylinder too and how much am I looking for parts and labour approx?
  1. clutch problems
    By merdock in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2010, 10:38
  2. Feel of clutch problem
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2006, 16:49
  3. Clutch problem
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2006, 01:28
  4. DSG Clutch problems
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2005, 20:34
  5. Hydraulic clutch problem.
    By imported_daryl in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2005, 04:34
