Volks AutosEM Tuning
Results 1 to 12 of 12
    Mar 2013
    blanking off rear wiper need to stop "water"r from working
    hi
    can any one please help me ,
    i'v just ordered a part to fill the hole where the rear wiper is ,(removing the arm and motor)< knackered
    now when i take out the washer motor and leave the water pipe hanging , if i accidentally press the stork to activate the rear washer i'm going to have water all over the boot
    i'v tried taking out the fuse but it also stops the front washers from working ,
    is there any thing i can do ?
    a3 2.0 tdi sline 04 plate
    thank you
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Put a bolt in the end? Pinch it with something? Tie it in a knot?
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: blanking off rear wiper need to stop "water"r from working
    Un plug the motor. Assuming it has separate rear motor.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Mar 2013
    Quote Originally Posted by chris.vincent3 View Post
    not a bad idea mate "little bolt and jubilee clip"
    Quote Originally Posted by Rom View Post
    not sure i can only hear the washer motor noise coming from the front of the car and assuming it will just be long hose to the rear will have to have a dig around never thought about that ,
    Mar 2012
    278
    Just about to do this myself. Was planning on squirting a little silicone into the pipe then screwing in a bolt whilst its still wet. Should ensure a watertight seal?
    Mar 2013
    Quote Originally Posted by SCFC_Messiah View Post
    dont see why it wont work , i gather there wont be too much pressure coming from the pump ,but just have look around on the net and the hose coming from the washer bottle at the front of the car is made up of a few parts (not one long hose) so there could be a possible chance that one of these section could fail and start to leak water in to the car , if you/i press the stork long enough
    not that were going to as we know theres no washer motor at the back
    so going to try and find the hose that leads to the back of the car from the main washer bottle under the bonnet and see if can blank it off from there ,
    so if theres a chance of accidentally pressing the stork , it will only leak from under the bonnet and not in the car ....
    Mar 2012
    278
    I don't think there's enough pressure to cause any problems. My nozzle has frozen over in icy weather in the past which stops the water from jetting out. I've held down the stalk hoping to get it to clear without causing any breakages or leaks from the pressure build up
    Mar 2013
    probably a bit over kill from my part , a guess an easy fix could a bolt /screw silicon and jubilee clip ,
    my wiper seized up a good while ago and when trying to move it i broke the wiper, and to be honest iv never accidentally pressed the stalk in ( well i dont think i have )
    Mar 2012
    278
    Ye my wiper motor is knackered too. It's stuck halfway up the window.... I don't see the point in replacing the motor, it looks better without the wiper and I can't say I've missed not having one considering it hasn't worked since I bought the car.
    I bought a custom window plug from Designstopfen - Heckwischerabdeckung, Blindstopfen, Kappe, Glasstopfen, De-wiper, Plug, Grommet, Cap. Very expensive at £23 (especially when rubber grommets are a couple of pence) but the thought of having my football clubs logo on it was just too cool
    Mar 2013
    ha ha
    that was the same place i ordered mine just the plain black glass one ,
    £23 was a bit much but tried to ordered one from dubmonkey.co.uk @£10 but couldnt get past the payment page so went the german company instead and got the glue with it ,,
    to replace the motor was going to be nearly £80 , just a bit too much for my liking ,
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    I'd be very surprised if Audi use one motor for front and rear.
    It's pretty common to use separate front and back, though obviously both are at the front.
    Allows better motor life, and in a pinch, can swap pipes over until you replace the dud motor.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Jul 2012
    55
    I press mine and it fires straight out past the front of the engine haha I need a gromit ASAP. Anyone know of any company's in the north west that stock these?
  1. Rear wiper stops off the window
    By Dan_Sykes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2012, 22:38
  2. Rear wiper wont stop!
    By 18 stoner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th February 2008, 01:22
  3. Rear wiper wont stop!
    By 18 stoner in forum General Technical / How To
    Last Post: 17th February 2008, 17:53
  4. Help Needed- Rear Wiper problem.
    By 1.8JT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2007, 15:46
  5. A3 rear wiper blanking plate.
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2006, 15:21
