Chris NottBadger5
Results 1 to 19 of 19
    TDI140's Avatar
    May 2011
    1,355
    Flat bottom mfsw
    Im bidding on a flat bottom steering which is multi fuction buttons on it, i lnow how to fit the actual steering wheel but will the airbag plug straight into my original airbag plug ? Also will that allow the multifunction steering buttons to work or is there more to this retrofit ?
    Also just to tell you i dont need the buttons to work as im not really bothered but i want the flat bottom steering
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    May 2011
    Portsmouth
    397
    Depends what steering wheel you have at the moment. Theres loads of guides out there but an example is I've just fitted my MFSW to my A3 about an hour ago. The airbag fits straight in with the dual harness becuase I have DSG but you may need an extra harness for your airbag.
    The buttons won't work, they need coding in with VCDS
    Fossie
    Rhubarb Triangle
    3,969
    What year is your car and are you bidding on the wheel AND airbag or just the wheel ?
    The airbag on the fbmfsw is different from the normal airbag
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    TDI140's Avatar
    May 2011
    1,355
    I have a standard steering wheel not dsg my car is a manual 6 speed 2006, what airbag harness will i need do you know the part number ? Or paste a link to a retro fit with pictures ive decided not to by one with buttons as i wouldnt use then as i think they are annoying, so a plain flat bottom steering 8J0419091 part number for plain flat bottom steering, what harness would i need to make a circular air bag fit straight in ?
    TDI140's Avatar
    May 2011
    1,355
    image.jpgThis is what my steering looks exactly like
    Jan 2012
    111
    Re: Flat bottom mfsw
    Just ask seller maybe the harness comes with steering wheel.
    To MF You needs also steering modul 8P0 953 549 F and sleep ring (im not sure if that's the proper name) but the part number is 1K0 959 653 D
    Without those 2 parts buttons don't working
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,404
    Your car will already have the correct slip ring but it won't have the steering control module. You need to get that in order to get the mf buttons working.
    There are literally thousands of threads already covered this topic... A simple search will help you get all the info you need
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    TDI140's Avatar
    May 2011
    1,355
    I wont need the module if i decide to go for the flat bottom steering withough multi function buttons also i just want to know if the new air bag will plug straight into the old airbag connection ?
    I searched pretty much all day yesterday and this is the first time i have got information clearly so thank you guys
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,404
    your right, if you dont connect the buttons up then you wont need the new module.
    the airbag loom may still be different as there may be different plugs and spade connectors that go on the back of the actual airbag
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    TDI140's Avatar
    May 2011
    1,355
    Quote Originally Posted by Ash187 View Post
    i will not be connecting the buttons up its more hassle than i want but is there a part number for the different airbag loom ? If so i will order that from audi as well
    Fossie
    Rhubarb Triangle
    3,969
    Airbag wiring harness part number : 8J0 971 589 A or whichever is the later revision. If you ask for that they will (should) give you the right one.
    About £45 I think.
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    About £45 I think.
    8J0 971 589 AD is the most recent one they're using now Mike. £41.45 it set me back a few weeks ago.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    TDI140's Avatar
    May 2011
    1,355
    Thanks mike do you know how much a brand new steering wheel is from audi without airbag
    TDI140's Avatar
    May 2011
    1,355
    Quote Originally Posted by leeds2592 View Post
    thanks pal ill go and order one of these from audi or TPS ive got trade accounts at both places by TPS is usually a bot cheaper
    Fossie
    Rhubarb Triangle
    3,969
    Cheers mate - isn't that for mfsw though ? I think TDI140 has decided to go for non-mffbsw !
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by TDI140 View Post
    Go with my number as the one Leeds2592 gave you is definitely for multi function wheel.
    Wheel alone from Audi is just under £450. Can't be absolutely accurate because prices have changed since my ETKA.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Oops, only read the original post and not the ones in between. My bad
    TDI140's Avatar
    May 2011
    1,355
    Sorry if i wasn't clear, i don't want multifunction buttons on my steering wheel so it will be a plain steering but flat bottom im just going to buy it from audi and pay full price cant be bothered waiting for ebay :-L, so mike your part number is correct for the flat bottom non multi function
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,404
    here is one
    Audi TT/ S3/ S4/ S6 Genuine Flat Bottom Leather Steering Wheel | eBay
    send seller an email and ask him how much he wants? you never know you can get a decent deal by offering to end the sale early
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  1. TT-S Flat Bottom MFSW FS
    By S5Gordo in forum For Sale/Wanted - Audi Parts
    Last Post: 11th July 2012, 11:26
  2. Flat Bottom MFSW Install Help
    By pattso187 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2012, 12:27
  3. Various Flat Bottomed MFSW with and without airbags
    By s8craig in forum For Sale/Wanted - Audi Parts
    Last Post: 14th December 2011, 10:27
  4. Just Retrofitted Flat Bottom MFSW!!
    By JamS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2007, 12:28
  5. Flat bottomed MFSW for S3
    By djhindley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2007, 16:52
