AH FabricationsSky Insurance
    Feb 2013
    78
    Spraying alloys ?
    Hi guys i know this question has been asked to death but i cant find any definitive answers to what i would like to know.
    I am supposed to be swapping my wheels for some dark anthracite wheels this weekend. One of the wheels has a deep kerb mark in the middle of one of the spokes.
    I presume i will need to sand this spoke down to bare metal so i can apply filler ?
    Should i keep my own wheels that only have a few kerb marks would it be ok to simply just scotch pad the wheels with a bit of compound to rough them up and then spray them with primer and then the colour i want or will i still need to sand down a fair bit first ?
    Any help or advice would be appreciated cheers
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: Spraying alloys ?
    You can fill and paint over painted surfaces.
    You need to at the very least key the surface with a Scotch pad or similar. So they product can adhere.
    The sanding process it to remove defects, and to shape filler. Always finishing on a higher grade, as paint won't be able to fill the scratches left by coarse paper. This does depend on the paint used, and who's doing it.
    Alloys are usually filled with different filler than bodywork, though I've seen body filler used.
    So yes, you could rub down, fill, rub down, and paint the damaged wheel. You can also just repair the damaged area, blend it in to rest of wheel, and re lacquer the whole thing.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Feb 2013
    78
    You a star thanks very much!
  1. 18" Alloy Wheel Re-Spray to different colour
    By A3Kent in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2012, 14:45
  2. DIY Alloy Wheel Spraying.
    By will-i-a-m in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2012, 06:54
  3. Replies: 2
    Last Post: 17th February 2012, 14:33
  4. Anyone got a pic of S-Line / RS6 alloys sprayed Gloss Black?
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2011, 20:47
  5. Spraying audi alloy wheels
    By jav786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2011, 00:29
