JMB RetrofitsVolks Autos
Results 1 to 17 of 17
    Jan 2013
    Rhondda South Wales
    23
    Post New wheels rubbing on rear arch
    Hi just put a set of 18x8 et 45 rs4 reps on my a3 tdi 2.0 2006 and they are rubbing on the rear arch on the outside of the tyre I've got 235/40 on there and the suspension is standard.
    158
    Need 225/40
    Jan 2013
    Rhondda South Wales
    23
    They told me in the tyre place to put 235 on them
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Then go back and say, thanks for your advice, they rub, can i has 225 now please
    Think most people run 225 tops, which is standard 17" width for the sport.
    Theres a arch liner screw you can remove which a lot of people do when lowered etc.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    8J's will rub. Standard fit is 7.5J
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    You mean 8j with 235 will, 7.5j with 235 wont ?
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Jan 2013
    Rhondda South Wales
    23
    ye read about this ill give it try
    Eftwyrd's Avatar
    May 2012
    42
    As others say, narrower tyres, remove screw or add more camber. They are your options.
    Oct 2011
    20
    no point adding camber
    just get 225/40
    standard r32 wheels that are 7.5j have 225/40 on them iirc
    Jan 2013
    Rhondda South Wales
    23
    Ok 225 it is then
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    Did you solve this? I have the same wheels but my a3 is lowered by about 40-50 mm. And it scrubs. Took the screw out and it's alot better but still does over bumps and if I had a full tank or 3-4 people in the car! thinking of having the insides of my wheels Lazor trimmed apparently? A friends dad I know does it? Any ideas? Only a couple of mm?
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Quote Originally Posted by Beagles View Post
    So basically raising the ET of the alloy? Thus bringing the wheel back into the arch.
    Jan 2013
    Rhondda South Wales
    23
    ive taken the screw out an it seems to have worked but I will be putting 225 on the next time I change the tyres.
    Burkin's Avatar
    May 2012
    derby
    173
    215
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    What's the ET? Sorry if I'm being simple here! I'm clueless with wheels and widths and offsets and all that! But basically yes. Wheel would go in a few mm or how ever much I request apparently? I've got 225 on mine now and I'm not crazy low! Think the back is fully down but tyres aren't up in the arch! Don't wanna raise it either
    Also, since I've put these rs4 wheels on, obviously the width and how far they stick out is different, but the car seems to wallow a little and I'm not sure if the cheapy budget tyres are causing this? Or the change in position of the wheels compared to the last ones! Any ideas?
    Appreciate all the replies guys!
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: New wheels rubbing on rear arch
    Et is offset, same thing. Higher the number, further in the arch the wheel sits.
    All the info we need is stamped on the back of the wheels.
    Something like 8j et45.
    What size tyres are you using, all numbers. Like 225/35/19.
    I'm on eibach sportlines, so 50/40mm on sport shocks. I have 8.5 wide wheels in front, et 45, with 225/35/19 tyres.
    Rears are 9.5 wide, et45, 225/35/19 tyres.
    So my rears are pretty wide, with arch screw out, I get minimal rubbing. Only if I hit a dip fast, normal driving, commuting is fine. Fronts don't rub at all.
    With exact details we can may be help more.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    I'm running 8J on 225 tyres. No rubbage at all. Even 5's up. Standard sport suspension.
  1. Replies: 28
    Last Post: 8th November 2011, 15:29
  2. Rear wheels rubbing on an Audi a3
    By j0bsy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2011, 14:28
  3. 19" bbs lm rubbing on the rear arches !!!!
    By soldier4313 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2010, 14:49
  4. Rear wheels rubbing on arch
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 12:51
  5. Rear Wheels Rubbing with Aftermarket Alloys
    By g1pkn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2008, 11:25
