Monster MotorsportVolks Autos
Results 1 to 7 of 7
Thread: Fault codes
    Jan 2013
    Rhondda South Wales
    23
    Fault codes
    Hi put my car a3 tdi 2.0 on a computer today and got these fault codes up one I knew about the over boost 16618 but I had this one to Glow plug cylinder 3 short, code 17057 is this just a case of changing the glow plug.
    Fossie
    Rhubarb Triangle
    3,969
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Jan 2013
    Rhondda South Wales
    23
    Cheers mike
    27,097
    What year?
    Jan 2013
    Rhondda South Wales
    23
    2006
    27,097
    BKD engine probably, so vanes sticking is 1st port of call if overboost errors.
    Log it again, does it go into limp mode up hills?
    Jan 2013
    Rhondda South Wales
    23
    Ye spoke to you early this week about its the glow plug one I wasn't expecting
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
