Sky InsuranceEM Tuning
    Oct 2011
    43
    Mr Muscle on a BKD - How too?
    Anybody got a guide / pictures of how exactly to do the Mr Muscle clean on the turbo on a BKD?
    Tried to follow others but the turbo seems to be in a very inconvenient place, different too other tutorials.
    Also, how the hell do you remove the EGR valve to clean? - I cannot get the third hex bolt out as there is no room between radiator and/or pipes around the front of the engine.
    Regards
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    Your best removing the whole turbo unit and cleaning it by stripping it down
    If you want to muscle it then you need to get the pipe in the top of the manifold where the EGR pipe bolts to (before the cooler)
    You should be able to remove the EGR valve with just an Allen key, it is a little tight and tricky!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    27,129
    There's plenty of room to get the egr/imf of, just patients/time needed & as above, remove the whole unit & clean it properly as the Mr Muscle way is temp solution at best.
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    If you have a Quattro I'd be prepared for a long day!
  1. S3 Bumper Removal - How too
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2014, 11:54
  2. Is there a "how too" for removing the front door cards on an 8L S3?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2013, 22:42
  3. Water marks & stone chips how too...
    By S3 Big Andy in forum Detailing
    Last Post: 18th May 2009, 12:01
  4. how too
    By ALPINE in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st November 2008, 19:56
  5. Adjustable Boost - How too??
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 12:55
