Badger5EM Tuning
Results 1 to 7 of 7
    SCHOLESY83's Avatar
    May 2012
    42
    Thumbs up S3 EXHAUST FITTING... EASY ENOUGH??
    Hi,
    I believe to change the 2007 S3 exhaust (2 piece turbo back) it requires removing the driveshaft? Is this true? Is that a straight forward job?
    Cheers in advance
    r7ano's Avatar
    Race Tech
    Mar 2008
    Daventry
    The prop shaft needs to be undone at the front to gain space to remove the down pipe.
    SCHOLESY83's Avatar
    May 2012
    42
    Cheers, straight forward job for any garage mechanic?
    r7ano's Avatar
    Race Tech
    Mar 2008
    Daventry
    Oh yes! Only 3 bolts
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Turbo flange bolts meant to be tricky.
    £80-£100 is the going rate for fitting.
    Worth it though as the gains are excellent.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    SCHOLESY83's Avatar
    May 2012
    42
    Straight forward job... Should have been. I'm now 1 bolt short where the heat shield/cover plate separates the drive shaft and exhaust. Turned out the guy didn't use the little tabs that retain / stop the bolts falling out and now the bolts on a slip road somewhere!
    does anyone know the correct way of using the little tabs that are on this plate? There's 4 tabs, but looks like only one of the 4 tabs is supposed to be bent over the bolts washer. Can anyone confirm?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,370
    This gives an impression of what a tight space it is....
  1. 225 exhaust fitting
    By TTLOON in forum TT/TT-S/TT-RS Forum
    Last Post: 30th June 2007, 11:51
  2. Supersprint Exhaust Fitted!
    By ChriS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2006, 19:03
  3. Downpipe, CAT, Exhaust! Fitted
    By mazzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2006, 19:14
  4. Pics of supersprint exhaust fitted to S3?
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2004, 21:41
  5. New Exhaust Fitted
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 19:16
