EM TuningJMB Retrofits
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By NHN
Thread: COOLANT PUDDLE
    Aug 2011
    277
    COOLANT PUDDLE
    From two holes in the rear centre of the engine undershield two puddles of liquid, plus slow loss of coolant.
    Will remove undershield this week-end to investigate which looks easy enough, a mixture of bolts and Torz screws. With a back problem this may well be a problem particularly if undershield is heavy. Gut feeling it will be more than a loose hose clip - the word water-pump comes to mind and thus a trip to my village garage ( not convinced need to waste money at Audi dealer, or should I? ).
    From this mechanical thicko to those of you brighter and more able to comprehend such things am I on the right track?
    27,075
    On what year, engine etc?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    COOLANT PUDDLE
    Ill put money on the radiator same as mine leaking.. Common problem look for white build up in the corners
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Aug 2011
    277
    2009 2.O L PETROL
    Aug 2011
    277
    Quote Originally Posted by JamesO View Post
    Thanks. Bunged some BARS anti-leak stuff I used in the olden days of classic car ownership. Doubt if it will work but out for a 30 mile run on Sunday so see if still leaking. Will check rad. as you suggest which I'm sure I can do without faffing about taking that floorpan shield off. Would prefer the rad. to be the problem rather than anything more complicated and expensive.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    COOLANT PUDDLE
    Quote Originally Posted by WAFTER View Post
    It's really common to be honest and you're right I am waiting for mine to get worse and I will replace. 70 quid for the rad and three hours labour isn't too bad.
    27,075
    Be very careful using these radweld etc solutions as it could block areas it shouldnt & therefore cause serious problems.
    Pressure test the coolant system over night & it should show the leak point then.
    OVRA3 likes this.
  1. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  2. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
  3. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  4. Coolant pipes
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2004, 23:10
  5. small puddle of water under car each time
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2003, 15:54
