Volks AutosChris Nott
    Nov 2012
    14
    S3 knocking noise from engine
    Ive had my S3 since November and all has been well untill now, its a 2007 with 40k on the clock but was bought from a main dealer so has the 12 month Audi warranty and goes in on Monday, but just wondering if someone else has had anything similar...
    Once the engine is warm you can hear what seems to be a top end knocking/tapping noise quite loudly from inside the cabin, this deffinatly isnt the usual injector noise and Audi have already comfirmed as much, its just they dont seem to know what it is either at the minute.
    You can also hear it under the bonnet but with the injector noise under there it seems more prominent from inside.
    I know its not much to go on but has anyone had anything similar? All seems fine otherwise.
    Feb 2009
    16
    Does the knocking noise stop if you put your fut on the clutch? Mine had a knocking noise and needed a new DM flywheel and gearbox after 6,000 miles.
  1. knocking noise from engine
    By Dan s3 audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2012, 17:16
  2. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  3. Knocking noise from my Coupe Drivetrain!
    By strokes in forum Handling
    Last Post: 6th October 2005, 16:33
  4. ticking noise from engine
    By chrisa4quat in forum Tuning
    Last Post: 13th September 2005, 06:34
  5. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
