AH FabricationsChris Nott
Results 1 to 12 of 12
Thread: OEM Rear Discs
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    OEM Rear Discs
    Hi.
    I am going to need to replace my Rear Discs soon.
    Can someone tell me what make the OEM ones are?
    Just want to get some prices, may even consider upgraded ones if they are a similar price.
    My motor is a 2008 A3 2.0 TDI 170.
    Chris
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Go to Eurocarparts website and order them from there - enter the discount code LASTCHANCE25 to get 25% off
    Did this for my rear discs last week and they arrived yesterday
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Quote Originally Posted by Boydie View Post
    Thanks for that, looks like Pagid are the OEM ones.
    Just spotted that each are different diameter.
    255mm, 260mm, 272mm or 286mm.
    Anyone know which is the right size?
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    411
    What PR code do you have for your rear brakes if you let me know I can tell you the right size you need.
    Aug 2012
    Aberdeen
    42
    Give lastchance30 a try also. Pretty sure I bought window wipers with that code
    SPARTAN91's Avatar
    Zookeeper Champion
    Nov 2012
    NORFOLK
    411
    CODES 002.jpg You will find your PR codes on this sticker in the front of your Audis service book or
    under the mat in the boot.This is the one form mine,The code you need is in box 5 second row down first code in
    so mine is 1KD which is the rear brake spec code and the fronts are the 3rd code in 1ZE
    I have a 58 reg 2.0 140 so mine are 255mm I think yours will be 260mm but the code will give me the correct answer
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Thanks for that info. I didn't know about those codes.
    Mine is also 1KD
    SPARTAN91's Avatar
    Zookeeper Champion
    Nov 2012
    NORFOLK
    411
    Snap so you will also need 255mm wide discs that are 10mm thick
    These codes are what were used to build your car as per the first owners spec order you can find out what they all are by looking them up on line
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Thanks for your help guys.
    Plus the Lastchance30 code works, i'll get them ordered tonight!
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    boooooooooooooooo 30 works? raging lol
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    haha, sorry to be the bearer of bad news! :-p
    Aug 2012
    Aberdeen
    42
    I should have been quicker to post that then. Did you also like I did try LASTCHANCE with various higher numbers? Was disappointed it only went to 30 :-)
