JMB RetrofitsSky Insurance
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By NHN
Thread: A3/S3 Glovebox Door
    ApolloS3's Avatar
    Jul 2012
    Newport, South Wales
    73
    A3/S3 Glovebox Door
    Hey guys,
    The door on my glovebox has been getting worse and worse, and finally last night it snapped in one corner, the latch mechanism is also horrific, it requires a very hard slam to close, anyone else find this?
    Does anyone know if audi sell just the door part? id rather not buy a whole new glovebox...
    Jordan
    Feb 2013
    129
    Mine's exactly the same, really temperamental. It's one of those things that if it costs a shed load to fix I can happily ignore but if it's £20-30, then i'll jump on it!
    27,033
    I have a whole glovebox here for sale.
    Apr 2003
    Bristol. United Kingdom
    233
    Quote Originally Posted by ApolloS3 View Post
    Hey guys,
    Jordan
    Just wanted to add a bit of feedback that the worst part of my S3 owning experience was the glove box door; so much so I had 3 different units replaced over the 6 years. Audi only seem to hold either the door plus hinge or the full assembly (door hinge plus glovebox), I never saw them replacing just the hinge (even when I asked during the last time). It is a definite weakness when used on every trip...
    12- A1 1.6TDI Sport Sportback Misano Red/Black, Black/Grey Tornado, Xenons, Tech Pack, Mobile Prep High, Bose, Rear Park, Cruise, Dim Mirror, Climate, LED Lights, Armrest
    07-12 S3 Sprint Blue, Leather & Buckets, Flat MFSW, Armrest & Phone Prep, Rear Park, Dim & Fold Mirror, Tyre Warn, Sunband, Interior Light, Cruise, Hill hold, Auto Light & Rain, Bose, Sat Nav+, iPod
    01-07 S3 Dolphin Grey, Blue/Black Alcantara, Bose, Armrest, CD, Cruise, Ali Mirrors, Heated Seats
    00-01 A3 1.8TQ Sport Red, Bose
    27,033
    The weak point is not the hinge as such, its the brake element that dries out over time & people pull it down to open it, which after a while stresses the joint, which any joint under a fair bit of stress would make it break.
    I've strengthened mine, but greased the brake part & its been fine since only because of the lube.
    ApolloS3 likes this.
    ApolloS3's Avatar
    Jul 2012
    73
    So far ive used WD-40 on the part you describe, it moves a bit better now but still not perfect, would silicone lubricant be better? Id rather not have to take the whole glovebox out if i can help it...
    Not sure how im going to get the hinge to stay together, super glue doesnt seem to be holding much under the weight of the door.
    27,033
    Jan 2012
    SW London
    794
    I completely removed my glovebox, used this (http://www.rapidonline.com/catalogue...77520P01WL.jpg) and put some weights on it to keep pressure on it overnight. Removed the brake element from the hinge and its been fine since. Not fussed about the brake, hardly use my glovebox as it is. The light wont come on if u remove the brake btw.
    If uve used superglue make sure u scrap all that off before using the hard plastics glue, and use a fair bit of glue too. Dont try to rush the drying process either, just let it set by itself
    27,033
    Innotec Topfix goes of in seconds & its like a weld joint afterwards, at £25 a tube its expensive, but I use it often for work & its brilliant, but the damn syringes are £1 each & they are chucked/renewed on each use of the resin, but its so much better than anyother resin/epoxy used before.
  1. Glovebox damper & N/S/F door lock
    By Crazyfool in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st November 2007, 13:17
  2. Door problem....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2003, 11:42
  3. Where can I get S3 interior door trim handles?
    By simonhenchie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2003, 11:18
  4. Bizarre door creak...
    By PreacherCain in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2003, 15:57
  5. S3 Front Door Speakers
    By mramage in forum In-Car Entertainment
    Last Post: 5th April 2003, 21:05
