Monster MotorsportEM Tuning
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By TDI140
Thread: Hybrid turbo or no?
    Feb 2013
    Cornwall
    81
    Hybrid turbo or no?
    Basically I have a 56plate 2.0L Tdi 170bhp, my turbo is whistling quite abit so I don't think it's going to last much longer than a couple of months.
    So instead of replacing it with another standard part I was thinking of a hybrid turbo.
    Is there any advantages of having a hybrid turbo and are they much more expensive?
    Also would I need to modify anything for it to fit or would it just bolt on?
    Thanks any help would be great
    May 2012
    York
    241
    Yes big advantage, capable of alot more power, you would probably need a new clutch and remap to make the most of it
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,447
    not much profit unless uprated injectors are fitted tbh.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    TDI140's Avatar
    May 2011
    1,327
    Quote Originally Posted by RedDejavu View Post
    he wont need injectors u less he wants even more torque and bhp but a direct replacement hybrid turbo will do just fine with a uprated clutch and new dual mass fly wheel, 170pd with hybrid from somewhere like turbo technics will get you 230 -250bhp after remap and depending on what other mods you have such as decat exhaust etc etc approx cost would be £1400 without rxhaust thats what ive priced up for my pd140 when my turbo dies
    martinivw likes this.
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Feb 2013
    Cornwall
    81
    Hybrid turbo or no?
    Quote Originally Posted by TDI140 View Post
    £1400 I take it that's fitted.
    Any idea of how much a hybrid turbo would be just to buy and where from?
    Don't know yet whether to buy just a standard replacement. Weighing up my options still
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,447
    220 is maximum for pd170 injectors I'm afraid and that can be reached without having a hybrid turbo fitted. Stage 2 is up to thier limits anyway so whats the point in wasting money?
    Now:
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    depends on which hybrid he fits
    Darkside GTB Turbo Kit for 2.0 16v TDI PPD & Common Rail Engines - Darkside Developments
    seriously though, I agree with Red,
    fit a standard turbo,remove dpf if u have one and remap to 220 hp
    if you go down the route of upgrading your injectors you will need a lot more ££££
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Quote Originally Posted by martinivw View Post
    Is all that other stuff in you link needed to have a hybrid turbo ?
    Stainless Tubular Exhaust Manifold
    3” Stainless Downpipe with Stainless 6" Flexi and Dual Fitment Flange
    Genuine VW OEM Manifold Gasket
    Genuine VW OEM Downpipe Gasket
    Darkside Braided Oil Feed Line
    Darkside Oil Return Line
    Genuine VW OEM Oil Return Gasket
    Silicone Turbo Inlet Pipe Connector Hose
    Stainless Clamps
    2.25" Silicone 60° Outlet Pipe
    All other nuts and bolts required for fitment
    I thought you just needed the hybid turbo....
    Feb 2013
    Cornwall
    81
    Hybrid turbo or no?
    Well in that case then. Where's the best place to buy a standard turbo? Audi dealers will be expensive and I don't really fancy buying one from eBay
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by Digzz View Post
    Stainless Clamps
    for hybrid you don't need all the above,
    the tubular manifold for example, is only needed if your fitting the GTB turbos from that page, the GTB 2260 (3.0tdi turbo ) or GTB 2566 which is a hybrid version of the 3.0 turbo !!!!, the 3" downpipe is needed to increase exhaust from turbo of course.
    my BKD has a hybrid version of standard turbo (bigger compresser wheel) which comes on standard manifold, oil change is recommended when fitting new turbo, as is new gaskets, oil feed line & oil return line my car also has standard exhaust fitted minus the cat all I need now is a new map and I will hopefully see 220ish hp ,
    check out this link for a great deal
    Darkside 1.9 & 2.0 TDI Budget Turbo Kit inc Fitting and Mapping - Darkside Developments
    Feb 2013
    Cornwall
    81
    Hybrid turbo or no?
    Also anyone know what the turbos are like to remove and replace?
    TDI140's Avatar
    May 2011
    1,327
    £1400 just for oarts ive priced up and thats without an egr delete and remap price after fitting with all of it put. 2K to the side
    ive just had a new intercooler due to mine being damaged but i would have changed it for a new one anyway if i was buying a hybrid as i found out mine leaked lots oil after removal which was disturbing so my budget fir hybrid after my turbo dies is £1600-£2000 everything fitted ! Ready to burn oil and release the torque
  1. hybrid turbo
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2008, 20:25
  2. New K04 Hybrid turbo
    By Backdraft Motorsport in forum Tuning
    Last Post: 8th January 2008, 17:03
  3. JBS05 K04 Hybrid Turbo Upgrade
    By JBS Alec in forum Tuning
    Last Post: 24th November 2007, 15:10
  4. What are Hybrid Turbos and has anyone fitted them to an S4?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2007, 15:07
