EM TuningChris Nott
    Chris-gsxr's Avatar
    Oct 2012
    57
    Advice needed on rear light
    I had some water inside the rear passenger side rear light on my 09 a3 sline a few weeks ago. I think I've solved that problem, but a new problem has popped up probably due to the water issue. The led tail light has gone out throwing up a bulb out warning on the dash. It's the actual led tube that's out not just a normal bulb. Are these fused individually? The drivers side tail light still works fine. If its not a fuse any suggestions what I can do next? Thanks in advance
    Sep 2012
    Birmingham
    31
    I had this issue on mine when I first installed them. I had to take them apart (bulb holder) and give the contacts a damn good clean. All has been fine ever since.
    Chris-gsxr's Avatar
    Oct 2012
    57
    Also the both parts of the led light is not working. One being on the boot lid,they have separate power and connections, that's why I thought it could be a fuse blown?
    Chris-gsxr's Avatar
    Oct 2012
    57
    Bump. Any more suggestions?
  1. Advice Needed: Seats Removal - Front and Rear
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2013, 10:10
  2. Advice on splitting rear lights to change bulbs
    By Rays18 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2012, 21:46
  3. Rear Bumper Advice Needed!!! pls!!
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2011, 21:43
  4. Advice on 2009 REAR Lights for 3 door
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2010, 09:21
  5. Need price for Headlight + Rear Light
    By unkle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2006, 20:45
