AH FabricationsVolks Autos
    Jan 2013
    159
    Audi S3 EVAP and fuel gauge readings
    Hi all, basically my car has had the charcoal canister cleaned out when it went in for some work at Awesome Gti but now the VCDS is bringing up an emission error to do with the EVAP system (I have cleared this code but keeps popping back up on VCDS)
    Now......I put 20 litres of fuel in before and the needle went up to just over 3/4 FULL tank!
    Obviously an issue here.
    Can anybody advise here please? Is it a valve that has gone or the charcoal cannister blocked again?
    A good thread is here....... The Audi TT Forum :: View topic - EVAP canister? N80? ** EDIT: SOLVED I THINK! **
    But need to look more into why my car thinks 20 litres of fuel is 3/4 full when it said there's almost no fuel left in the car at all (range said 5 miles and needle was firmly in red!)
    Car is a 2007 reg S3 with 63k miles on it.
    Any advice would be excellent.
    PS- The car is only run on Shell V power and I have not fully filled the car with fuel just yet.....But I did notice a problem last week when i filled 35 litres in it and it gave me a full tank and a range of 365 miles...Obviously not right!
    Jan 2013
    159
    The car is also under warranty through a secondary warranty company but obviously want to try and resolve this before it goes away for weeks on end!! Maybe worth fitting new dials to it or would that be too over the top?
    Jan 2013
    159
    Just has this good bit of info from a Audi mechanic
    "Yep, the evap canister can break up causing the fault. There is a basic setting that tests the evap system but i cant remember which channel it is on. Taking the hose off the canister and running the test succesfully will point to a defective canister
    I have had a handful where the canister has broken up and blocked the solenoid valve.
    As for the fuel gauge, thats difficult to say without testing stuff. Its going to be either the dash insert or the fuel gauge sender, with a small possibility of the fuel pump control unit"
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    how about filling the tank to see if that recalibrates things.
    2009 A3 SB 2.0T DSG S line
    Jan 2013
    159
    Cheers! Im sure there is something in VCDS that will test it all so may look at this on the weekend or something. If not, its going in for repair!
  1. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  2. Airbag light and Fuel Gauge FAULT!!!
    By jetturk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2010, 08:31
  3. Fuel gauge reading !! Can't be right ..
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 12:13
  4. 2006 A6 Fuel gauge reading empty.... (2.7 tdi)
    By A6Ian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th May 2010, 10:39
  5. Had a flat battery now fuel gauge reads empty.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2009, 19:34
